what model and engine please
29 Oct 2012 21:44 #556290 by cjcrug
what model and engine please was created by cjcrug
I bought this bike about a month ago,slowly trying to bring it back to life. Id like to know what model and engine i have. The po said it is a 1979 kz 1000 ltd. The frame and engine numbers are as follows. Frame # KZT00B517299 Engine # KZT00AE058867. I do know it has been bored to 73mm and has andrews 2x cams. I believe this thing should be NASTY once i get it running. Kerker 4 into 1 also. Any info would be greatly appreciated, thank you.
79 KZ 1000 B3 LTD
Wiseco 1105
Kerker 4 into 1
Dyna s ignition
Dyna green coils
K and n pods
Andrews 2x cams
  • 4TheKZ1000
  • Visitor
29 Oct 2012 21:54 - 29 Oct 2012 22:13 #556291 by 4TheKZ1000
Replied by 4TheKZ1000 on topic what model and engine please
cjcrug wrote: I bought this bike about a month ago,slowly trying to bring it back to life. Id like to know what model and engine i have. The po said it is a 1979 kz 1000 ltd. The frame and engine numbers are as follows. Frame # KZT00B-517299 Engine # KZT00AE058867. I do know it has been bored to 73mm and has andrews 2x cams. I believe this thing should be NASTY once i get it running. Kerker 4 into 1 also. Any info would be greatly appreciated, thank you.
This is what I found....two different years...could be wrong but looks right. This info was found above right "FILEBASE".....
1979 Kawasaki KZ 1000 B3
Frame# KZTOOB-515537 - 523543
_____________________________________
1978 Kawasaki KZ 1000 B2
Engine# KZTOOAE-057037 - 057066 & KZTOOAE-058797 - 075473
Last edit: 29 Oct 2012 22:13 by 4TheKZ1000.
29 Oct 2012 22:00 #556292 by cjcrug
Replied by cjcrug on topic what model and engine please
thank you, any info on engine, i think it may have been changed
79 KZ 1000 B3 LTD
Wiseco 1105
Kerker 4 into 1
Dyna s ignition
Dyna green coils
K and n pods
Andrews 2x cams
The following user(s) said Thank You: 4TheKZ1000
  • wireman
30 Oct 2012 01:25 #556329 by wireman
Replied by wireman on topic what model and engine please
From what Ive been told over the years the 79 ltds basically got left over 78 kz1000 bottem ends with updated charging systems with the newer style smog motor cylinder head,then in 1980 the ltds got the same motor as the mkII bikes.
Theres nothing wrong with the older style motors,it just got caught in the middle of a parts change over is all B)
30 Oct 2012 08:05 - 30 Oct 2012 08:08 #556348 by LarryC
Replied by LarryC on topic what model and engine please
wireman wrote: From what Ive been told over the years the 79 ltds basically got left over 78 kz1000 bottem ends with updated charging systems with the newer style smog motor cylinder head,then in 1980 the ltds got the same motor as the mkII bikes.
Early 79's are like that. Later 79's got the MKII cranks, cam chains and sprockets. There used to be a serial number range on the Kaw microfiche that gave the information.
If the motor is a 78 and virgin, it will have the old head & old style engine covers plus old style charging system, small pin crank with full circle counter weights, points ignition, etc...
Larry C.
Last edit: 30 Oct 2012 08:08 by LarryC.
