SLEEPLESS IN VENICE Low compression in KZ900 all 4
- jerry chabino
My trusty Kz 900 is ill. It will not idle correctly (carbs rebuilt) , backfires, no power, and afterfire. I installed Wired by George's coil fix and it starts better but still runs like sh**. Compression is 110 to 115 in all cylinders. If I add a teaspoon of oil to the plug port the compresion climbs to 160 plus. What seems odd though is that the bike only has 9500 miles. How could the rings be bad and why all of the cylinders reading about the same.??? Thanks in advance for the help.
Sleepless in Florida,
Jerry
- 4TheKZ1000
- Visitor
- Kraz1
- jerry chabino
a hot engine. It only jumped up approx 5 lbs per cylinder.
Thanks,
Jerry
- jerry chabino
Carbs were professionally rebuilt last year . I was hoping that was the issue and had them rebuilt just because they have been untouched for some many years. Still ran crappy.
I also installed new points, plugs, coils, wires plus George's fix.. I have the point dwell set at 22 Deg per set and timing was done with a strobe. I added some Seafoam to the crankcase and fuel tank.
Thanks a bunch for your time,
Jerry
- KZJOE900
- Admin
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- Thank you received: 2829
- jerry chabino
Joe,
Hopefully our fellow KZ folks will clarify the compression issue. I live in Venice.
Ed,
Stock filter system, but I have the filter out while working/testing things. Do you think I should install the filter/airhorn before test rides ?
jerry chabino wrote: Thanks KZJoe and 650 Ed,
Joe,
Ed,
Absolutely. KZ engines run poorly if the air filtration and jetting don't match, so with no filter, horn, etc. your engine will very likely not run right. Ed
- jerry chabino
- jerry chabino
Installed everything, no change
- DoubleDub
- Visitor
- Check Valve Clearances
- Check Ignition Timing/Points Condition
- Check Spark Quality
If the problem isn't found at that point:
- Leak Down Test
