- Thank you received: 6
Standard bore, high compression pistons. KZ900
- CrazyDuck
Does anyone make such pistons? I have seen standard bore KZ1000 10.25:1 pistons but no 900 pistons. I know I could do a special order through Wiseco but that gets quite expensive.
1976 KZ900
1974 TX500
1978 TT500
2007 Aprilia SXV
- racer54
- Thank you received: 114
- Bozo
- Ride it like u stole it
- Thank you received: 105
I've had many bikes since but the Z always stayed because of these mods........GO FOR IT
- LarryC
CrazyDuck wrote: I found a low mileage bike that had not been started since 1985. The cylinders are perfect, everything in the engine looks like it is brand new. No carbon deposits anywhere in sight and absolutely no wear on anything. All I want to do is bring the compression up to the 10.25:1 mark from the lousy 8.5:1. Better fuel economy and a little extra power. I have been searching for a while and all I see is big bore kits.
Raising compression from stock to 10.25:1 isn't going to buy you a heck of a lot for the cost of the pistons. It will make a difference. However on a dollar / hp ratio, it's a poor investment.
Without tearing things apart, the best initial investment you can make is good carburetors. Follow that up with or in combination with good drop in cams and you'll be better served in the dollar / hp ratio investment.
Unfortunately, there are no reasonably priced performance carburetors available anymore. Used smoothbores are a crapshoot. New ones cost a bunch. Going to CV carburetors can bring headaches you may not be ready for also.
So where does that leave you? Here's a realistic approach that should be relatively painless. Find some drop in cams for $150 or so. Bolt them in, adjust the valves, rejet your stock carburetors and ride it.....
Larry C.
- CrazyDuck
The poor bike sat outside for 27 years after being low-sided which made it look really bad so I only paid $300 for it. The damn thing still had the original tires!
I want the bike to handle better in the twisty mountain roads. I have to get another swingarm to upgrade to the rear disc brake so that will probably go for a better swingarm while I am at it.
1976 KZ900
1974 TX500
1978 TT500
2007 Aprilia SXV
- BohicaBob
- Thank you received: 35
- Kraz1
CLICK
> 900 Pistons
CLICK
> American Classix 69.4 Pistons
- APE Jay
- Banned
- Thank you received: 58
