- Thank you received: 13
Does Vance and Hines 13013 fit 79 kz1000E1 shaft?
- Roadflyer
25 Oct 2012 19:18 #555745
by Roadflyer
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
Does Vance and Hines 13013 fit 79 kz1000E1 shaft? was created by Roadflyer
I have a Mac chrome 4-1 pipe that came with my shaftie when I bought it. The pipe is OK but not up to the rest of my restoration for looks. The mounting tab at the rear of the pipe is about 3-4 inches back from the rear footpeg mount and it was connected by a black steel strap, the look is cheesy. So my question is, will the vance 13013 street pipe mount on the footpeg bolt like it should or come with a make shift mounting strap too?
- Roadflyer
30 Oct 2012 12:29 #556380
by Roadflyer
Replied by Roadflyer on topic Does Vance and Hines 13013 fit 79 kz1000E1 shaft?
bump
- 4TheKZ1000
- Visitor
30 Oct 2012 12:35 - 30 Oct 2012 12:43 #556381
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Does Vance and Hines 13013 fit 79 kz1000E1 shaft?
Sorry I cant be more help....try this!
Technical Support
tech@vanceandhines.com
Vance & Hines
13861 Rosecrans Ave.
Santa Fe Springs, CA 90670
Phone: (562) 921-7461
Technical Support
Vance & Hines
Last edit: 30 Oct 2012 12:43 by 4TheKZ1000.
- wireman
- Thank you received: 299
30 Oct 2012 16:22 #556411
by wireman
Replied by wireman on topic Does Vance and Hines 13013 fit 79 kz1000E1 shaft?
Most headers require some sort of mounting bracket between the 2
- Roadflyer
31 Oct 2012 15:33 #556570
by Roadflyer
I'll give them a try, thank you.
- Roadflyer
31 Oct 2012 15:35 #556571
by Roadflyer
That's what I was afraid of. i'm so tempted to cut this one off and weld a new one on that will fit under the peg bolt the way it should.
wireman wrote: Most headers require some sort of mounting bracket between the 2
