- Thank you received: 391
KZ1100 Cylinder Sleeve, got one?
- Motor Head
21 Oct 2012 22:51 #555073
by Motor Head
KZ1100 Cylinder Sleeve, got one? was created by Motor Head
Hey I need one KZ1100 Cylinder sleeve for my big bore project, so it will get bored. It can have scoring or rust in the bore, no biggie. Just need one to finish up my big bore project, not in a hurry, sometime in the next couple of months or so. thanks.
- Motor Head
25 Oct 2012 09:46 - 10 Nov 2012 12:07 #555704
by Motor Head
Replied by Motor Head on topic KZ1100 Cylinder Sleeve, got one?
Bump
Or the part # from LA Sleeve or Wiseco, stock or going to 75mm bore?
I Finally Heard Back from LA Sleeve and got the part #. KA169, I found one on Feebay new with free shipping for $53. On its way.
Got the sleeve, but found it is a Big Bore sleeve that needs both the block and cases bored out. I was looking for a Stock external size sleeve. Try again.
Still looking for the Stock 1100 sleeve. :dry:
Last edit: 10 Nov 2012 12:07 by Motor Head.
- Motor Head
10 Nov 2012 12:10 - 04 Dec 2012 11:37 #557750
by Motor Head
Anyone know what sleeve would be the stock replacement for the KZ1100 cylinder block? Found it to be KA744 from LA sleeve. I'm trying to return/ exchange sleeves, so hopefully it will work out.
Looks to be 3.080" OD, 4.540" Tall, and 4.015" at the top flange.
All Done, ready to be put together once a few more parts show up.
Last edit: 04 Dec 2012 11:37 by Motor Head.
