New cam chain idler
- built408
13 Oct 2012 10:53 #553615
by built408
1978 KZ1000 A2A with MKII body you know you like it
New cam chain idler was created by built408
I just got my new idler I was wondering if I should soak it in oil before I install it?
Thanks!
Thanks!
- Jeff.Saunders
13 Oct 2012 11:15 #553620
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic New cam chain idler
It's a good idea to make sure any of the parts are lubed during assembly so that on startup they are not dry. I don't soak idlers, but I do lubricate parts like idler bearings with oil during assembly. Then before I put the cam cover on, I empty a quart of oil over the buckets, cams, cam chain and idlers while manually turning the engine over.
Z1 Ent on Facebook,
- built408
13 Oct 2012 12:28 #553638
by built408
Replied by built408 on topic New cam chain idler
Thanks Jeff I got my idler from you last night looks great! Thanks Paul from Tampa Fl.
