- Thank you received: 50
Need Z1 float bowls. 74/75
- etbike3135
10 Oct 2012 22:03 #553519
by etbike3135
1973 Kawasaki Z1
18 years in dragbikes
Need Z1 float bowls. 74/75 was created by etbike3135
I need 2 float bowls for a set of Z1 Mikuni carbs either 74/75. The ones with the drain screws and the nuts. I need one from each side.
1973 Kawasaki Z1
- z1wiz
19 Oct 2012 23:59 #554791
by z1wiz
Over 30 years with z1's, Currently down to only one 75, a j model dragbike, and 2 KZ1000 dragbikes.
Replied by z1wiz on topic Need Z1 float bowls. 74/75
Did you ever find them?
Russ
Russ
