KZ440 Kick Starter Mod
- Austin440
07 Oct 2012 23:35 #553009
by Austin440
1981 KZ440 LTD
KZ440 Kick Starter Mod was created by Austin440
I am wondering if there is anyone out there who has experience with fitting a kickstarter to the 440 LTD models. I am fairly certain that the clutch cover on my 440 is the same casting pattern and the same bolt pattern as earlier 400 models that have kick starters, the only difference is they did not bore out the kick starter hole on the 440.
Is fitting a kick starter as easy as using a cover from an older model and sliding the kick starter into place, or would the crank case need to be drilled out in any way on the inside to fit the shaft? If so, it's probably not worth it, but having the kick starter can be really nice with how cold blooded the bike can be on those cooler days.
Let me know if anyone has experience with this modification.
1981 KZ440 LTD
- Nebr_Rex
- Thank you received: 300
08 Oct 2012 01:04 #553022
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic KZ440 Kick Starter Mod
You have to split the cases, been there, done that, and the covers are different.
For more info do a search on the kz400.com forum.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
