Cam cap issue?
- built408
07 Oct 2012 15:52 - 07 Oct 2012 15:53 #552928
by built408
1978 KZ1000 A2A with MKII body you know you like it
Cam cap issue? was created by built408
Is a problem? my buddy pointed this out to me saying this is a problem and needs to be replaced. If it does need to be replaced I can't seem to find one does anyone have any ideas? Also does anyone know where I can get one it's the #1 cap. Thanks.
Last edit: 07 Oct 2012 15:53 by built408.
- built408
07 Oct 2012 17:09 #552933
by built408
Replied by built408 on topic Cam cap issue?
Any Ideas???
- 4TheKZ1000
- Visitor
07 Oct 2012 17:31 #552939
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Cam cap issue?
bearings?? looks like cam is walking in cap bore.
- Kraz1
07 Oct 2012 17:33 - 07 Oct 2012 17:38 #552941
by Kraz1
Replied by Kraz1 on topic Cam cap issue?
No eBay APP ID and/or Cert ID defined in Kunena configurationYou can replace the Cam Cap. These Caps were machined with the Head that they came with respectively. So when you acquire a few for fitment purposes, you will be trying them out to see if when installed the Cam will turn without binding. You may go through a few Caps before finding one that works.
Don't be scared.
Of course it could never hurt to have a spare head.
Don't be scared.
Last edit: 07 Oct 2012 17:38 by Kraz1.
- zed1015
- Thank you received: 1557
07 Oct 2012 20:06 - 07 Oct 2012 20:12 #552960
by zed1015
Replied by zed1015 on topic Cam cap issue?
The damage probably is not that bad.
Someone has bolted the cap down with the cam off to one side and chipped the casting.
Maybe the visible damage is the worst it gets as it's broken off a bit of casting at the thinnest point.
I see it a lot and even though the cam may float it is never enough to cause trouble.
as long as the camchain and sprocket bolts can't chew the head casting or the cam lobes run off the shims it'll be ok.
Rotate the engine by hand while pushing on the end of the cam to see how far it will go left and right I'd bet there isn't that much movement.
If the engine was running fine camshaft wise and there's no sign of something touching where it shouldn't you haven't got a problem.
Last edit: 07 Oct 2012 20:12 by zed1015.
- built408
07 Oct 2012 21:11 #552975
by built408
Awsome thanks sed I tryed to move the cam and it wont budge I even tryed to add a little pressure with a screw driver with a rag wraped around it and 0 movement :woohoo: . It ran perfect before I took the valve cover off I was getting the classic noice at 3500 to 4000 rpm and took the valve cover off to inspect the chain idler and its nice and loose so I'm replaceing it and found the 650 bucket and the chiped cap. I think I will just put the new idler on put the valve cover on and leave it be for now then save some cash and pull the head off and just send it to Jo at pitstop for his $311.00 rebuild.
- 4TheKZ1000
- Visitor
07 Oct 2012 22:25 #552990
by 4TheKZ1000
that engine would make a great boat anchor...... :lol: :lol: :lol: :lol:
- Tomolu5
- Thank you received: 45
07 Oct 2012 22:35 #552993
by Tomolu5
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
Replied by Tomolu5 on topic Cam cap issue?
Might as well check the valve lash while your there
Mine:
