- Thank you received: 2
Mismatched pistons
- sc/ant864
Attachment IMG_20121004_233903.jpg not found
kzrider.com/forum/11-projects/543276-77-...543286]'77KZ900-1000 streetstrip project
'77KZ900/1000
'89BMW E30 325i sedan
'88Mustang GT
'77Datsun PL620 KingCab
George Carlin- "I often think how different the world would be if Hitler had not been turned down when he applied to art school."
- 4TheKZ1000
- Visitor
- wireman
- Thank you received: 299
- Motor Head
- Thank you received: 391
Same bore size and Dome for even compression/ power/ force on the crank also.
- sc/ant864
Motor Head- Yes I planned on weighing them all with my digital scale once I make a wrist pin press and thanks for the tolerance estimates.
'77KZ900/1000
'88Mustang GT
- wireman
- Motor Head
- OldSchoolZ
- Thank you received: 33
Thats ok, I have to pull the bottom case half off the motor in the bike I just bought cheap. They broke off 2 bolts on the lower case, JB welded crap and cross drilled the bolts trying to remove them. Time to EDM them I guess.
Some goof balls have no business working on anything.
This should be everyone's motto
"Lord grant me the bravery to fix things I know I can fix, the strength to accept the things I cant, and the wisdom to know the difference"
Remember, don't work on your bike so much you never ride it.
- wireman
- sc/ant864
wireman-Measured the pistons with my crappy calipers and came up with 70mm.
OldSchoolZ wrote: Ive seen crazier shiz though. Thats proof many people have no business working on bikes. If someone is taking the time to pull a top end, they might as well do it right.(Im sure they got lucky regarding the weight issue) :whistle:
'77KZ900/1000
'88Mustang GT
- bountyhunter
- Thank you received: 337
wireman wrote: If all else fails Id say try to match 1-4 as a set and 2-4 as another according to the piston skirts
That's what I thought since they run as sets.
Could you take a Dremel and shave the bottom of the skirts on the heavier ones?
Just curious.
- kzz1king
- Thank you received: 52
Wayne
Home built KZ1000 turbo setup
