carbs stumble on launch
- dwyer
05 Oct 2012 13:19 #552610
by dwyer
carbs stumble on launch was created by dwyer
Hey there, been messing with my 83 kz440ltd carbs for weeks, new diaphrams,stock jets, float setting is correct, new float valves, carb mounts, ect. idles great and pulls good over 1600rpm,but still can't get it to pull away from a stop smoothly. any suggesttions or recomendations would be great. thanks
- Thank you received: 2098
05 Oct 2012 14:31 #552628
by Patton
Hello, dwyer, and WELCOME to KZrider forums.
If running pods instead of the stock air box, it's more difficult to tune the carbs for acceptable performance throughout their full range from closed to WOT.
A strong smooth pull-away depends on well-functioning carb pilot circuits.
The pilot circuits may need cleaning, and possibly also need new and/or perhaps larger pilot jets.
Replied by Patton on topic carbs stumble on launch
dwyer wrote: Hey there, been messing with my 83 kz440ltd carbs for weeks, new diaphrams,stock jets, float setting is correct, new float valves, carb mounts, ect. idles great and pulls good over 1600rpm,but still can't get it to pull away from a stop smoothly. any suggesttions or recomendations would be great. thanks
- Thank you received: 2829
05 Oct 2012 17:32 #552643
by 650ed
Replied by 650ed on topic carbs stumble on launch
What are you using for air filtration? Ed
- dwyer
05 Oct 2012 18:02 #552652
by dwyer
Replied by dwyer on topic carbs stumble on launch
Thanx for the help running stock air box withe new filter, will look at pilot jets and ports again. Soaked carbs in vood clean "dip" before rebuilding but could still have som goo lol
- Motor Head
- Thank you received: 391
05 Oct 2012 20:52 #552673
by Motor Head
Replied by Motor Head on topic carbs stumble on launch
Have you used the Mixture screws to tune the slow speed/ Idle circuit? Turning these out another 1/4 turn each may help depending on where they are set at now and the engine demand.
