750 Twin Head Gasket Source
- pistolpete
17 Jun 2006 17:07
I would really like to buy it individually, but I've only come across it for $90. Any sources I should check?
I assume that I need to use a new head gasket when replacing the head. I also assume that I need a new head when the PO knocked the bike over an chipped off 3 corners of the fins on the head. Or can I just ignore the broken fins and let it ride?
- wireman
Re: 750 Twin Head Gasket Source
17 Jun 2006 20:42
as long as its not overheating ,ride the wheels off of it.
- steell
18 Jun 2006 06:40
If you really need a head gasket you can usually get a complete top end gasket set for the 750 twin for around $25 on eBay.
- cnyl
18 Jun 2006 09:07
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
North Port, FL
Check out my band
- pistolpete
19 Jun 2006 15:29
More people chip in and tell me if wireman is correct. I won't hold you to it if my bike puts a hole in a piston, but I want a realistic answer. Three head fins missing on one side, chipped off at the coner, and only there. Whadaya think?
- Werewolfx
19 Jun 2006 15:31
I would seriously doubt it will cause you any trouble, if its not overheating, ride on, wrench in the off season (if you have an off season)
Chris
- Biquetoast
- King Jeremy The Wicked
19 Jun 2006 15:52
pistolpete wrote:
I think that as long as it's only external damage, it won't make any noticable difference. With air flowing around the engine, it should be just fine.
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- steell
