Head gasket dimensions asap
- Pop147
01 Oct 2012 19:41 #551865
by Pop147
Head gasket dimensions asap was created by Pop147
I need the dimensions of a stock head gasket for a kz750 b4 if anyone has them or knows where to look it would really help me out.
- bountyhunter
- Thank you received: 337
01 Oct 2012 20:03 - 01 Oct 2012 20:11 #551866
by bountyhunter
Replied by bountyhunter on topic Head gasket dimensions asap
No eBay APP ID and/or Cert ID defined in Kunena configurationNot sure what you mean by "dimensions". Are you trying to cut one yourself? I don't think it will work.
Here is a set that contains the head gasket for a 1979 KZ750 B4.
www.oldbikebarn.com/KZ750-Twin-Athena-En...sc=12&category=74739
Here is a Kawi gasket:
Last edit: 01 Oct 2012 20:11 by bountyhunter.
- Pop147
01 Oct 2012 20:18 #551870
by Pop147
Replied by Pop147 on topic Head gasket dimensions asap
have you used the athena set?
- bountyhunter
01 Oct 2012 20:22 - 01 Oct 2012 20:25 #551871
by bountyhunter
Problem is Vesrah does not make a full set for the 750 twin, but they do claim to make the head gasket which is their part HG 4014. have no idea if that is true.
Yes, I used it for my rebuild. The head gasket was good quality. The green "paper" gaskets were not good (the cylinder base gasket disintegrated in a few hours time) and the cheap cardboard valve cover gasket was crap. It's possible I got a bad set that was too old?Pop147 wrote: have you used the athena set?
Last edit: 01 Oct 2012 20:25 by bountyhunter.
- Pop147
01 Oct 2012 20:29 #551873
by Pop147
They do make a full set, i got one but the head gasket didnt fit thats why i was looking for dimensions.
- bountyhunter
01 Oct 2012 22:45 - 01 Oct 2012 22:47 #551893
by bountyhunter
catalog.vesrah.co.jp/list/vintage_gasket.asp
The head gasket is available as OEM on ebay and also in the Athena set.
Their web site says they don't make a set. If you got one and it doesn't fit, that sounds like they don't make a set for that bike. You can try the searcher here:Pop147 wrote: They do make a full set, i got one but the head gasket didnt fit thats why i was looking for dimensions.
Last edit: 01 Oct 2012 22:47 by bountyhunter.
