Hardt to shift gear when engine is warm
- marcus91
When the bike is cold gear-shifting goes really smooth. When the bike gets warm though, its a pain to gear up from first to second. The bike does not go past neutral. It seems to be blocked. When I gear up and down like this 3-4 times it usually hits the right gear (second). All of the other gears seems fine. No problem at all when Im gearing down from second to first.
Any suggestions of what the cause of the problem might be...?
1981 Kawasaki Z650SR
- Del_Herring
- Thank you received: 29
1983 KZ750-N2 Spectre
- marcus91
And this system is probably inside the gearbox I assume..? Not something I can fix with the engine on the bike?
- wireman
- Thank you received: 299
Have you tried adjusting the clutch?
- marcus91
- wireman
- baldy110
- Thank you received: 512
Del_Herring wrote: When are you trying to shift, these bikes have a "neutral finder" feature which blocks out second until you're going a few miles an hour. If you're trying to shift early, it could still be activated. I think it's just a spring and ball detente kind of system, so it might be hanging up when cold or warm, and either not locking when cold, or not unlocking once warm for some reason. Maybe someone else has more ideas.
FYI the 650's do not have the "nuetral finder"
