- Thank you received: 229
Sidewinder install.
- zukdave
30 Sep 2012 18:09 - 01 Oct 2012 01:51 #551725
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Sidewinder install. was created by zukdave
So since no one ever made a sidewinder pipe for the small four's
I picked up a KZ900/1000 V/H pipe to cut up and make fit.
Started with cutting about 2" off the old header to make some adapter spigot's at the head.
Then cut the collar's off the S/W pipe and used a ratchet strap and pulled the out side tube's in to
fit the 750 head.
Next was trim the tube's to bring the pipe closer to the motor.
Ended up cutting at the rust line from the collar's.
When I pulled the one and four pipe's in the no. 1 tube raised up about a 1/3" so I put two
thin cut off wheel's on the grinder and cut it low behind the center tube's to help hide the weld
and the worked dead nut's.
fit the 750 head.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 01 Oct 2012 01:51 by zukdave.
- Del_Herring
- Thank you received: 29
30 Sep 2012 18:23 #551726
by Del_Herring
1983 KZ750-N2 Spectre
Replied by Del_Herring on topic Sidewinder install.
Good work. How are you supporting it in the back. It looks like there might be something there in one of the pictures, but I can't tell. Any clearance issues? looks a little close to the road.
- 4TheKZ1000
- Visitor
30 Sep 2012 18:31 #551728
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Sidewinder install.
thats some gr8 work...looks like it was made for bike. well done!
- zukdave
30 Sep 2012 18:58 #551731
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Replied by zukdave on topic Sidewinder install.
Right now the back 1/2 is just hangin by a bungee cord.
Gonna do an offset piece of tube to move it up and in next
to the swing arm.
Stock foot peg still bolt's on but I need to work
out the brake pedal.
After readin about how much you need to cut one
to fit my little motor that's BS.
Other then triming the tube's at the head I cut ONE tube ONE time.
to the swing arm.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- wireman
- Thank you received: 299
30 Sep 2012 20:20 #551740
by wireman
Replied by wireman on topic Sidewinder install.
Looks like it belongs there to me,How much bigger are the tubes than your old pipe?
I wonder how its going to affect your jetting,maybe you can experiment with differant baffles to keeop from losing too much torque if the tubes are much bigger
The following user(s) said Thank You: BlackZ1R
- zukdave
01 Oct 2012 01:48 #551797
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Wireman the old primary tube is a snug fit inside the
new primary tube so one tube size up.
I think the new is about 1 9/16" inner
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- timebomb33
- Thank you received: 10
01 Oct 2012 02:35 #551798
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Sidewinder install.
looks pretty good like that,
- timebomb33
01 Oct 2012 02:36 #551799
by timebomb33
definitly starting to look like a real race bike
- zukdave
17 Oct 2012 00:05 #554273
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
New header's done and rode a little.
Motor like'd this new pipe
like a crack whore with a $20 dollar rock.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- wireman
17 Oct 2012 07:24 #554297
by wireman
:woohoo:
- built408
17 Oct 2012 20:26 #554391
by built408
1978 KZ1000 A2A with MKII body you know you like it
Replied by built408 on topic Sidewinder install.
Looks Nice!!
- undiablo
- Thank you received: 64
17 Oct 2012 21:01 #554399
by undiablo
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
Replied by undiablo on topic Sidewinder install.
Nice work, awesome!
