Starting but not idling
- candyskateboards
-bike will start but won't idle
-weak battery
-2&3 exhaust pipes were warm but not 1&4, after starting
-battery shorts out now when using electric start
-headlight no longer on
- Thank you received: 2829
- baldy110
- Thank you received: 512
- Tomolu5
- Thank you received: 45
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
- Chaotic Reason
- Thank you received: 15
As for the starting, I agree with baldy, it sounds like they are clogged. You said you put them back on a couple of days ago... Does that mean that you rebuilt them? If not, I'd take them off and let them soak in some pine-sol for a few days. Then clean them out real good and give it another go.
Michael
1980 KZ1000 shaft drive
- boyd825
- Ride it like you stole it!
- Thank you received: 3
1977 KZ1000 A1
- candyskateboards
- candyskateboards
How do you suggest swapping coils? Can I just put the spark plug cables from 2&3 on to 1&4?
candyskateboards wrote: Got a new battery but still the same problem. I looked at the coils and was going to swap 1&4 cables on to 2&3's coil but this is the second time I've ever look at coils. My other bike you thread the spark plug cable on and the oem kz's are not like that.
To swap coils you need to move the spark plug cables from 2&3 on to 1&4 and vice-versa, AND you need to swap the wires that connect the coils to the points. You do this at the coils. When your finished, the coil that was originally connected to points pair 1&4 is now connected to 2&3 and vise-versa. Ed
- candyskateboards
edit:spark on 4 is weak and purple and 1 is a strong and white.
