wireman wrote:
maybe the nut just fell off of center of drum.ok here comes the gasket police!
Nope, not the gasket police, but the nut police.
There are no nut there. The clutch is held in place on the shaft with a circlip.
If the clutch worked fine before you replaced the cable you should check the cable attachment to the release mechanism. Be shure the arm on the mechanism isn't moving the wrong way when you pull the lever. And when you adjust the freeplay in the release mechanism, be shure to have a lot of freeplay in the cable, then loosen the locknut and turn the screw in till it's loose. Then turn the screw out till you feel som resistance and then in again 1/4 turn and fasten the lock nut. Then take up the slack in the cable. This is the right way to adjust the freeplay on the KZ400B, and the KZ440 models with the release mechanism on the left hand side of the engine. And I assume the picture in your avatar is a 440 B or C model.
Post edited by: ibsen22000, at: 2006/06/18 05:00
Post edited by: ibsen22000, at: 2006/06/18 05:03
