Splitting casses on '80 KZ 1000
  • Fastdave61
  • Fastdave61's Avatar Topic Author
21 Sep 2012 22:40
#550201
My '80 KZ 1000G is jumping out of 2nd gear under hard acceleration. I have tried all the easy stuff like new detent arm & spring, and an overshift bushing but it still jumps out. My conclusion is that 2nd gear needs replacing or under cutting. I asume that I will have to split the cases. My question is, can I remove the engine, turn it upside down and remove the bottom half with out removing the top end? I just did a top end last winter, wish I'd have known about the tranny problem then, but bike wasn't running when I got it. Any help will be appreciated. Thanks in advance. Fasstdave61
1969 BSA A65F Firebird
2004 BMW R1150RT
1980 Kz1000G1
2008 Triumph Tiger 1050
Bemidji, Mn
  • wireman
  • wireman's Avatar
Re: Splitting casses on '80 KZ 1000
21 Sep 2012 23:24
#550208
Yes you can do that B)
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
22 Sep 2012 05:14
#550229
I'd start with a shift fork change and you can do that without splitting cases. Pull the counter shaft sprocket (front sprocket) and the cover plate like you would to install the overshift bushing. Drop the oil pan. From that point you'll see how to go about it.
Les
  • Fastdave61
22 Sep 2012 23:57
#550336
Les: Thanks so much for your reply. I will try new forks, hope that does it, don't want to split the cases. This site is great, its been a lot of help.
Fastdave61
2004 BMW R1150RT
1980 Kz1000G1
Bemidji, Mn
  • OldSchoolZ
  • OldSchoolZ's Avatar
23 Sep 2012 01:56 - 23 Sep 2012 01:59
#550349
I'd replace all gears associated with 2nd gear. The gear dogs(gear locking tabs that lock with the other gear) get worn and no longer have a sharp edge allowing it to slip off and pop out of gear.
If you only replace one gear, you're doing it wrong so to speak. Replace the clips that you take off to remove the gears as well, once they are sprung, they dont fit as tight.
Also replace the shift fork associated with 2nd gear. If you miss a bad part, you'll be doing it again soon. ;)
P.S. use 1104 or kawasaki bond on the cases for reseal.I use it on all covers even ones with gaskets, guarantees no leaks.
Remember, don't work on your bike so much you never ride it.
Last edit: 23 Sep 2012 01:59 by OldSchoolZ.
  • Garn
  • Garn's Avatar
23 Sep 2012 05:45 - 23 Sep 2012 19:34
#550365
Sounds as so you will need to split the crank-cases. The trouble will probably be the rounding of the engaging pegs on fifth gear.
To save confusion the gears in trouble will probably be on the "Sprocket" shaft, also known as the "lay" shaft and/ or the "Output" shaft.
The gears in trouble are both the second gear, which is at the end closest to the sprocket ball-bearing end and the fifth gear which is the next to it.
On inspection you should notice a rounding of the pegs on the fifth gear and possible a rounding of the edge of the oval holes in second gear. If there is too much clearance (end-float) you may be able to use a slightly bigger "thick" washers (which are usually approx 4mm), which is between the above mentioned ball-bearing and second gear.
RegardZ.
PS. you can do this job without removing the head or cam cover. Also, just read the bike wasn't running when you obtained it. You will have to do a detailed check of the position of all spacers, particularly the "Thick" washer.
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
Last edit: 23 Sep 2012 19:34 by Garn.
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
23 Sep 2012 10:05
#550375
If the dogs are worn and you gotta replace the gears. I would just a whole other trans and have it back cut. And if i was you id get another mk11 trans there stronger. The mk11 have the a step on the gears unlike the earlier models.
1977 KZ 1000 work in progress
  • woodsy
  • woodsy's Avatar
23 Sep 2012 12:31
#550387
Looking at the manual i can't see any reason why you can't split with the top end in tact, i used to do that with my CB7504, as for jumping out of gear, possibly worn dogs or bent selector fork or combination of both
KZ 1000 B3 ltd - Imported from USA in 1994 - Live in Cornwall UK
