stops at 4K RPMs
- brentsspectre
21 Sep 2012 15:48 #550119
by brentsspectre
stops at 4K RPMs was created by brentsspectre
Thanks to the guys who helped get my carb problems sorted out!
Got the bike running and no more gas leaking...but it wont rev over 4K RPMs?? Accelration is fine, idle is fine, but I just cant get the engine over 4K RPM's?
Its a KZ750N.
Its a KZ750N.
- Del_Herring
- Thank you received: 29
21 Sep 2012 15:57 #550122
by Del_Herring
1983 KZ750-N2 Spectre
Replied by Del_Herring on topic stops at 4K RPMs
I feel like I've seen this kind of thing before in other threads. The advancer not working right can cause top end power loss, but I wouldn't think it'd be that severe. Try running with the gas cap open, sometimes they don't vent right, and it starves fuel. Is it like a sudden drop in power, or is it just tapering off to where you can't go any furhter? Same in every gear?
- brentsspectre
21 Sep 2012 18:52 #550162
by brentsspectre
Replied by brentsspectre on topic stops at 4K RPMs
Just tapers off, wont rev over 4K, no matter what gear I'm in. I'll try the gas cap trick.
