KZ1000 odd vibration / judder @ 2200 rpm
- woodsy
21 Sep 2012 14:01 #550094
by woodsy
KZ 1000 B3 ltd - Imported from USA in 1994 - Live in Cornwall UK
KZ1000 odd vibration / judder @ 2200 rpm was created by woodsy
I have a 1979 KZ 1000 and it has an odd vibration / judder at 2200 - 2500 rpm, it feels like engineas it happens in all gears at that rpm, possible thought is clutch judder maybe, any ideas anyone and how to fix it
cheers
cheers
- wireman
- Thank you received: 299
21 Sep 2012 14:27 #550103
by wireman
Replied by wireman on topic KZ1000 odd vibration / judder @ 2200 rpm
Tune up/clean carbs.............
Check motor mount bolts.........
- woodsy
21 Sep 2012 15:12 #550113
by woodsy
Replied by woodsy on topic KZ1000 odd vibration / judder @ 2200 rpm
engine bolts good an tight, just had the carbs apart and are totaly clean, bike runs smooth as anything
- Thank you received: 2098
21 Sep 2012 20:11 #550178
by Patton
Replied by Patton on topic KZ1000 odd vibration / judder @ 2200 rpm
If not already done, would assure valve clearances are within specs, and that the timing advancer is properly functioning.
- PRM068
23 Sep 2012 09:58 #550374
by PRM068
1982 KZ1000 LTD
Replied by PRM068 on topic KZ1000 odd vibration / judder @ 2200 rpm
I've been experiencing bad engine vibration for ages now.....looks as though it's a dud valve. I've pulled the plug leads off each cylinder to see if it makes a difference to the motor, and No 2 always does nothing.....it's almost dead.
Mind you, when I install a brand new plug, it runs great and smooth for about 80 mile, then starts playing up again. Still has heaps of power though.
I've doing a valve clearance check this week.
1982 KZ1000 LTD
23 Sep 2012 10:49 #550381
by Patton
A too high fuel level in the float bowl can be one reason why a good-firing new spark plug quickly fouls out.
Could perform the clear tube test to determine whether fuel level is within specs.
The clear tube test will also indicate whether a float valve is leaking, because the level just keeps rising regardless of the float valve being supposedly closed.
A seriously leaking float valve is another possible reason why a good-firing new spark plug quickly fouls out, due to overly-rich mixture being furnished from the carb.
PRM068 wrote: ...when I install a brand new plug, it runs great and smooth for about 80 mile, then starts playing up again....
- woodsy
23 Sep 2012 12:26 #550386
by woodsy
Like i said the engine is running as smooth as anything, perfect in fact so not valves or anything like that, it feels more like transmission
- PRM068
25 Sep 2012 07:33 - 25 Sep 2012 07:38 #550749
by PRM068
1982 KZ1000 LTD
Hey Patton,
I've been meaning to get around to doing that tube test, but was wondering if you actually need the proper "official" kawasaki stuff to do it, or can i just grab any old bit of tube ?
I looked it up in the manual - just haven't had time yet. When i pulled the carbs out, I pulled both 1 and 2 apart and compared them.....just quickly. The float level for both seemed about the same, but there's that word...."seemed".
And WOODSY....that's the thing.....my engine runs pretty smooth also. It's only when you're out on the road doing reasonable speed that you really notice it.
Peter.
Peter.
1982 KZ1000 LTD
Last edit: 25 Sep 2012 07:38 by PRM068.
25 Sep 2012 08:40 - 25 Sep 2012 08:41 #550752
by Patton
Any clear tube that fits snugly into the drain hole will suffice.
An appropriately sized clear plastic tube may be "self-threaded" into the drain hole.
Slight minimal leakage doesn't invalidate the test.
So long as the fuel level is within specs per the clear tube test, it really doesn't matter what the dry-measured float height happens to be when the carbs are disassembled upside-down on the workbench.
Where the fuel level is for whatever reason completely screwed up, the dry measured float height may be first adjusted to achieve a hopefully acceptable starting position for the clear tube test.
Last edit: 25 Sep 2012 08:41 by Patton.
