Need help, poor idle
- yiro90
20 Sep 2012 14:17 #549897
by yiro90
Need help, poor idle was created by yiro90
I have a 1979 Kz 1000, it is idling poorly and it has to start at half choke or more and its somewhat poor so when i accelerate to get it off the choke there is a pop and it runs great then dies out.
- Del_Herring
- Thank you received: 29
20 Sep 2012 16:12 #549911
by Del_Herring
1983 KZ750-N2 Spectre
Replied by Del_Herring on topic Need help, poor idle
starting with choke is pretty much the standard, that's why it's there. Once it's warmed up, should be able to turn it off. What do you mean about "accelerating to get it off the choke"? Is that once you've been riding and it's warmed up, or right after starting?
- toad
- Thank you received: 7
21 Sep 2012 09:39 #550043
by toad
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
Replied by toad on topic Need help, poor idle
check for nice spark, check wires make sure it runs on all 4 cylinders first.make sure carbs are clean and synched proper.
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
