kawaski z250c
  • trent250c
  • trent250c's Avatar Topic Author
Re: kawaski z250c
22 Sep 2012 06:26
#550232
when I turn it of and on it sparks as well...
Kawasaki z250c 1982
Re: kawaski z250c
22 Sep 2012 07:38 - 22 Sep 2012 07:39
#550235
May aid diagnosis to bear in mind that "ungrounding a charged coil" is the event which causes it to fire.
Good Fortune! :)
Last edit: 22 Sep 2012 07:39 by Patton.
  • loudhvx
  • loudhvx's Avatar
Re: kawaski z250c
22 Sep 2012 13:55 - 22 Sep 2012 13:58
#550276
nevermind. I realized this may be a different igniter than the mechanical advance ones.
Last edit: 22 Sep 2012 13:58 by loudhvx.
  • trent250c
Re: kawaski z250c
23 Sep 2012 07:03
#550367
how do I fix that?
Kawasaki z250c 1982
Re: kawaski z250c
23 Sep 2012 09:52
#550373
Does the bike have an electric starter?
If the bike has an electric starter, is it possible to spin over the engine by using the electric starter?
Does the bike have a kick starter?
If the bike has a kick starter, is it possible to spin over the engine by using the kick starter?
Good Fortune! :)
Re: kawaski z250c
23 Sep 2012 10:17
#550378
No eBay APP ID and/or Cert ID defined in Kunena configurationOne of several current ebay offerings:
Good Fortune! :)
  • trent250c
Re: kawaski z250c
23 Sep 2012 22:01
#550489
it has an electric starter, what do you mean by spin over
Kawasaki z250c 1982
  • Motor Head
  • Motor Head's Avatar
Re: kawaski z250c
24 Sep 2012 00:28
#550537
Patton means to "Spin" the motor with the electric starter or the kick lever.
Do you have a way to do electrical tests, like a Meter or test light? Find a manual to use yet? I see the pdf manual I linked doesn't have your year Ignition system, but has a lot of other useful info.
  • trent250c
Re: kawaski z250c
24 Sep 2012 05:39
#550568
the motor does turns, and I haven't found a manual and don't have test lights, sorry I'm not much help.
Kawasaki z250c 1982
Re: kawaski z250c
24 Sep 2012 07:59
#550571
trent250c wrote: well my bike bike wont start, i done the spark test and it sparks once then i get nothing and if i turn it of and back one i get spark but only one, any ideas how to fix this?
trent250c wrote: when I turn it of and on it sparks as well...
A better description of the "spark test" might be helpful.
For instance, is the spark plug removed for the test and held grounded against the engine to see spark at the end of the spark plug where it's supposed to spark?
Good Fortune! :)
  • trent250c
Re: kawaski z250c
24 Sep 2012 08:08
#550572
I have done it like that with the spark plug out and tried it with a spark plug in.
Kawasaki z250c 1982
Re: kawaski z250c
24 Sep 2012 08:47
#550576
trent250c wrote: I have done it like that with the spark plug out and tried it with a spark plug in.
What "spark test" was done with the the spark plug in?
Good Fortune! :)
