woodruff key found on drain plug
- readtaintor
18 Sep 2012 16:09 #549477
by readtaintor
woodruff key found on drain plug was created by readtaintor
Friends,
I have a '76 KZ900B. While changing oil, found a woodruff key on drain plug. Dimensions: about 3mm thick,5mm high and 13mm long. Any ideas where it came from. Trans? engine? I'm concerned. Any help would be much appreciated.
Read Taintor
Read Taintor
- 4TheKZ1000
- Visitor
18 Sep 2012 16:35 - 18 Sep 2012 16:49 #549482
by 4TheKZ1000
Replied by 4TheKZ1000 on topic woodruff key found on drain plug
YIKES....my KZ 1000 dosent have any....this should be the only WOODRUFF KEY 92038-001
Attachment crk.png not found
Last edit: 18 Sep 2012 16:49 by 4TheKZ1000.
- Tomolu5
- Thank you received: 45
18 Sep 2012 16:49 #549486
by Tomolu5
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
Replied by Tomolu5 on topic woodruff key found on drain plug
Would not run the engine until you ring out where that's from! I would go through the microfiches at kawasaki.com, or bikebandit.com to see what you find. I haven't been into my bottom end to know
Mine:
- Jeff.Saunders
18 Sep 2012 17:16 #549498
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic woodruff key found on drain plug
It would have to be from the rotor keyway on the LH end of the crank. If the rotor was removed at some point, it may have been displaced when the rotor was installed - or potentially, it was never in the keyway and came off during assembly.
Overall I wouldn't be too concerned. If you have time, I would pull the stator cover, and remove the rotor to check. Even if it's missing, the rotor will likely stay in place as that's exactly what they did on the KZ1000 - eliminated the keyway.
Z1 Ent on Facebook,
- readtaintor
18 Sep 2012 18:01 #549510
by readtaintor
Replied by readtaintor on topic woodruff key found on drain plug
Thank you all for your help! I'll pull the rotor and have a look. It's nice that there is a magnetic drain plug and that this forum exists! Best Regards, Read
- wireman
- Thank you received: 299
18 Sep 2012 22:17 #549582
by wireman
Replied by wireman on topic woodruff key found on drain plug
If it comes loose youll find out when you hit the starter button and it makes a funny noise in stator cover,ive sheared more than 1 off on really high compression z1s over the years. :laugh:
