Ignition switch
- Calico
18 Sep 2012 13:46 #549452
by Calico
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
Ignition switch was created by Calico
So I brought home a cycle dolly and put my 82' 750LTD on it to try things out. It was a tight fit steering the bars to the left so that I could remove my key. Later when I went to take it off of the dolly, the key would go in but will only rotate about an 1/8". I've tried the ole "jiggle the key while tapping on the back" thing but nada
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
- pete greek1
- Thank you received: 185
18 Sep 2012 15:44 #549471
by pete greek1
Replied by pete greek1 on topic Ignition switch
are you talking about the steering lock, or the ignition ?
- Calico
18 Sep 2012 15:54 #549474
by Calico
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
Replied by Calico on topic Ignition switch
Both actually. Out of curiosity, I bypassed the steering lock sorta and straitened it out but the key still won't budge
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
- Calico
19 Sep 2012 10:31 #549656
by Calico
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
Fixed! WD40 and a ton of patience
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
