1980 KZ1000G Classic
- bemery
18 Sep 2012 13:00 #549446
by bemery
Bob from St. Charles Missouri
1980 KZ1000G Z1 Classic
Fuel Injected
1980 KZ1000G Classic was created by bemery
Does anyone know what brand and model headers fit the Z1 Classic? I have called Vance and Hines and they do not know.
Fuel Injected
- Mellvis
- Thank you received: 3
18 Sep 2012 16:25 #549480
by Mellvis
Replied by Mellvis on topic 1980 KZ1000G Classic
Should be able to use any pipe from a Z1 900/KZ900/KZ1000,KZ1100. IF it still has the fuel injection on it (many have been switched to carbs) you may want to do some research on adjusting the fuel/air mixture prior to changing exhaust.
By the way, welcome to KZRider. If you put the basic information of the bike (year, model, any modifications that have been done) in your signature you tend to get faster and more informed answers. We also like pictures around here!
- roy-b-boy-b
- Thank you received: 103
18 Sep 2012 18:50 #549516
by roy-b-boy-b
Replied by roy-b-boy-b on topic 1980 KZ1000G Classic
I used a Kerker and a Mac on my Classic. They are the same headers I used on all my 900/1000 bikes I have owned in the last 14 years.
- Primer
- Thank you received: 4
18 Sep 2012 19:11 #549520
by Primer
Replied by Primer on topic 1980 KZ1000G Classic
I also have a Kerker exhaust on my '80 G model.
- bemery
19 Sep 2012 08:39 #549644
by bemery
Fuel Injected
Replied by bemery on topic 1980 KZ1000G Classic
Thanks for the info. I will get pictures up as soon as it looks a little better (winter project)
Fuel Injected
- Mcdroid
- Gone Kwackers
- Thank you received: 317
19 Sep 2012 12:32 #549666
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic 1980 KZ1000G Classic
Be careful...V&H do not fit on all models...for example, V&H sold for the A series KZ1000 do not fit on the KZ1000 B series (and the G model is very similar to the B series). I suspect that any V&H designed for the B series KZ1000 will work on the G model.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- wireman
- Thank you received: 299
19 Sep 2012 12:44 #549667
by wireman
Replied by wireman on topic 1980 KZ1000G Classic
Only differance between the models should be the bracket between megaphone and frame,which is easy to make/bend from a piece of steel strap
