APE CAM CHAIN IDLER
- built408
16 Sep 2012 20:36 #549127
by built408
1978 KZ1000 A2A with MKII body you know you like it
APE CAM CHAIN IDLER was created by built408
I need a good opinion on the APE CAM CHAIN IDLER . Its about time for me to replace mine and I was doing research and I found ape has a nice looking peice for $129 and the cheepest stock idler I found was for around $138 . Does the APE require modifaction to fit because that would explain the cheeper price which would make it not worth it. Thanks.
- 4TheKZ1000
- Visitor
16 Sep 2012 20:47 #549129
by 4TheKZ1000
Replied by 4TheKZ1000 on topic APE CAM CHAIN IDLER
Is it red
- built408
16 Sep 2012 21:01 #549132
by built408
Replied by built408 on topic APE CAM CHAIN IDLER
Yes its red. I was also looking at their stock replacement idler I think their pt# Is 12057-001hp with idler spacer blocks pt#z1bl1000 it looks to be a better quality part than a stock replacement.
Let me know what you think. Thanks.
- 4TheKZ1000
- Visitor
16 Sep 2012 21:21 - 16 Sep 2012 21:31 #549139
by 4TheKZ1000
the red adapter/Idler allows the use of a GPZ1100 or 1000J model cylinder head on the earlier KZ900 / 1000 lower end. Its not for a KZ head.
I would get the 12057-001
the solid mounts are a bit noisy compaired to OEM rubber ones. I would use OEM.
Last edit: 16 Sep 2012 21:31 by 4TheKZ1000.
- built408
16 Sep 2012 22:56 #549153
by built408
Whats your opinion on the ape 12057-001 vs a standard oem idler?
- 4TheKZ1000
- Visitor
16 Sep 2012 23:08 - 16 Sep 2012 23:11 #549157
by 4TheKZ1000
I would use it in mine....just not the metal mounts....I have a OEM in mine now! APE is a good product.
Last edit: 16 Sep 2012 23:11 by 4TheKZ1000.
