- Thank you received: 3
KZ1000Z1R: Can pistons, rings be changed in frame?
- 300kph
15 Sep 2012 20:08 - 15 Sep 2012 20:10 #548914
by 300kph
1978 KZ1000 D1 (Z1R)
1979 KZ1000 A3 (MKII)
1979 Honda CBX (Candy Glory Red)
1980 Suzuki GS1100E (Silver)
1980 Suzuki GS1100E (Red)
1978 Yamaha XS1100
1982 Suzuki GSX1100S (Katana)
1984 Kawasaki KZ1100R (Silver)
2004 Honda Rune (Bloodstone Red)
KZ1000Z1R: Can pistons, rings be changed in frame? was created by 300kph
Or do u have to pull the engine?
Also... are valve shims sold in kits or do they have to be bought indiviually? Special tool required for shim removal?
1978 Yamaha XS1100
Last edit: 15 Sep 2012 20:10 by 300kph.
- wireman
- Thank you received: 299
15 Sep 2012 20:24 #548916
by wireman
Replied by wireman on topic KZ1000Z1R: Can pistons, rings be changed in frame?
Yes you can do a topend with motor in frame,Id suggest atleast pulling the pan and checking pump while youre in there.
Its easier/cheaper to buy shims you need as you need them,Ive managed to collect buckets of them I should measure/organize them some day.
The following user(s) said Thank You: BlackZ1R
- Bozo
- Ride it like u stole it
- Thank you received: 105
16 Sep 2012 00:59 #548988
by Bozo
Replied by Bozo on topic KZ1000Z1R: Can pistons, rings be changed in frame?
What Wireman said
