Crankshaft main bearing caps
- Powerstroke_fan
14 Sep 2012 21:15
Today i was working on getting the bottom end put together on my new engine build. I dropped the crankshaft in alligned the races with the dowels and made sure its all sitting properly. I Install the main bearing cap making sure its facing the right direction. I snug the bolts by hand then torque them using proper sequence and torque value. I go to verly spin the crank and it wont budge. So i start looking and i noticed that the new H/D timing chain is tight against the plastic slider/guide that is bolted on the main bearing cap. It wasnt doubled over or anything. It is mk11 cases with mk11 crank. Had a 1000 crank in it when i got it. So the question i have is, Are the plastic sliders/guides diffrent on the earlier 1000s compared to the mk11's?
1977 KZ 1000 work in progress
- wireman
Re: Crankshaft main bearing caps
14 Sep 2012 21:37
You can use a 900/1000/or mkII crank in any 900/1000 cases between 73-80
- Powerstroke_fan
14 Sep 2012 21:40 - 14 Sep 2012 21:42
So whats the deal then? The chain is tight against the plastic it even indented the plastic from where i torqued it down. If you get the plastic slider/guide switched from end to end will it cause this?
Last edit: 14 Sep 2012 21:42 by Powerstroke_fan.
- wireman
14 Sep 2012 21:42
Can you post a picture of whats hitting?
I dont have any motors sitting here at new house yet that I can look at
- Powerstroke_fan
14 Sep 2012 21:49
Heres the best picture i can get.
- wireman
14 Sep 2012 21:56
The mkII crank has an extra tooth on the sprocket compared to the regular crank,I guess I never thought about that causing an issue.
ill check a couple sources to see if part number is differant
- Powerstroke_fan
14 Sep 2012 21:58
Ya i looked on some sites i could find with oem parts diagrams but none cover the crankshaft or main bearing cap.
- wireman
14 Sep 2012 22:06
Same problem im running into on babbits.com
- LarryC
14 Sep 2012 23:05
The main bearing cap comes with the cases. You won't find it listed alone.
Toss the plastic guide if it's causing a problem or clearance it....pretty simple.
Larry C.
- wireman
14 Sep 2012 23:08
Larry is there any differance between that guide between the regular kz bottem end and mkII?
- APE Jay
15 Sep 2012 04:16
I remember when those came out Manley sold them and it was before the MK11. The center pin and sprocket is larger, so the chain diameter is bigger. I can see why it would hit.
- LarryC
15 Sep 2012 07:57
Guys used to have problems getting the chain on the crank sprocket when installing the cams. That's the main purpose for that guide. If you set the bike level, there really is no problem getting the chain securely on the crank sprocket.... I don't run them in my motors.
Larry C.
