Generator Question
- PaulyWally
- Total Bike Newbie
14 Sep 2012 18:38 #548681
by PaulyWally
1976 KZ750 Twin
Generator Question was created by PaulyWally
As some of you know, I'm in the middle of trying to repair my starter clutch. It is assembled on the back of the "dynamo rotor". My question is: is the dynamo rotor supposed to be magnetic for the generator to operate properly?
I ask because my dynamo rotor has zero magnetism. But the bike has been recently used and the battery never drained.
So what's the deal?
So what's the deal?
1976 KZ750 Twin
- Thank you received: 2098
14 Sep 2012 18:53 - 14 Sep 2012 18:55 #548685
by Patton
Replied by Patton on topic Generator Question
Thinking the model at hand is electro-magnetic (requires battery voltage) as opposed to being a permanent magnet style.
Turning the ignition switch ON should produce some magnetism.
Take a look at the wiring diagram in KZr's FILEBASE.
Last edit: 14 Sep 2012 18:55 by Patton.
- gd4now
- Denco where did you go?
- Thank you received: 439
14 Sep 2012 19:29 #548692
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic Generator Question
IIRC the 76 750 B1 (twin) came stock with a 3 phase excited field alternator. So no the rotor will not be magnetic until the field is excited via battery voltage and the rotor is spinning.
1977 KZ650 B1
- steell
15 Sep 2012 12:52 #548845
by steell
Correct, applies to 76-77 model KZ750B.
(Except the rotor never gets magnetic, the coil generates the magnetic field)
Replied by steell on topic Generator Question
gd4now wrote: IIRC the 76 750 B1 (twin) came stock with a 3 phase excited field alternator. So no the rotor will not be magnetic until the field is excited via battery voltage and the rotor is spinning.
