- Thank you received: 105
GPZ900/1100 Clutch slave cylinder fitted to my Z1R
- Bozo
- Ride it like u stole it
14 Sep 2012 09:33 #548609
by Bozo
GPZ900/1100 Clutch slave cylinder fitted to my Z1R was created by Bozo
I've had a few enquiries about my slave cylinder fitting to the standard Z1R cover.
I used a GPZ (ZX for USA) 900R slave cylinder and a ZX1100 master cylinder, the critical part is to ensure the slave cylinder is central with the clutch actuator rod.
If its not central the cylinder will leak.
The Clutch cylinder line was made specially, note how it routes past the starter motor.
I don't have a drawing of the adapter dimensions so the adventurous types will need to do some prototyping, I used a 3mm thick ali plate, I did file some of the slave cylinder lettering on the face side and you will notice a slot where the cable outlet is.
If you have other questions let me know, but I don't want to remove it again unless it is urgent, enjoy.
P.S I do travel a lot for work and at times my responses will be delayed.
Attachment DSC09261.JPG not found
Attachment DSC09260.JPG not found
Attachment DSC09259.JPG not found
Attachment DSC09258.JPG not found
Attachment DSC09235_2012-09-14.JPG not found
- BlackZ1R
- Kawasaki in my blood
- Thank you received: 47
14 Sep 2012 10:36 #548614
by BlackZ1R
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
Replied by BlackZ1R on topic GPZ900/1100 Clutch slave cylinder fitted to my Z1R
Good job Bozo. I see you used the mid 80s 3 bolt style slave. I ended up with a '97 2 bolt style from a ZX9r. Will look at this a bit closer.
Kawasaki
- mark1122
- Keep twisting it
- Thank you received: 109
14 Sep 2012 13:19 #548634
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic GPZ900/1100 Clutch slave cylinder fitted to my Z1R
did u remove the ball bearing from the slave? How?
How did u align/center, the slave to the clutch rod?
Nice job.
Nice job.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Bozo
14 Sep 2012 18:50 #548684
by Bozo
Replied by Bozo on topic GPZ900/1100 Clutch slave cylinder fitted to my Z1R
Mark, there was no ball bearing on the slave that I know of. I round the rod at the end so it sits
In the piston dimple, the rod length was about right but you will have to experiment, the piston should be
all the way in but allow2 or 3 millimeters for clutch expansion when hot.
To align the rod I used the outer hole on the cover, I fitted a plate roughly cut but with the two counter sunk
Mounting holes and tried to draw a centre point using the existing big hole as a guide then I positioned the slave
and mounted it. Unfortunately the first plate was out by a mm (the slave leaked). The way I check the centre was with blue dye on the end of the rod, so I then made a second plate (easy by this time) and it was spot on.
- Bozo
14 Sep 2012 19:05 #548687
by Bozo
Typing on my IPOD is a joke, I forgot to mention, the slave has to sit flat on the plate
you need to make cut outs and remove the outer writing on the slave with a file. The
side cover is not modified in any way, so it can go back to standard.
I was supprised at how easy this mod was and I'm still kicking myself for not doing it sooner.
Because my Z1R had an original set of handle bars I had to buy a new MX set (lower) to
fit the master cylinders under the fairing, good luck.
