- Thank you received: 52
Pumpgas,octane, compression ??
- kzz1king
I am running a 1075 kit, 10/1 I believe.
Wayne
Home built KZ1000 turbo setup
- wireman
- Thank you received: 299
- 4TheKZ1000
- Visitor
10.25 to 1
Im running Turbo Blue racing fuel.....110 octane.
I can really tell difference over pump gas....smells cool when burt also...LOL
- Powerstroke_fan
- Thank you received: 83
4TheKZ1000 wrote: kz 1000.....1075
10.25 to 1
I bet that gets expensive i just run only premium 93 octane. Sometimes i go to the gas station close by where they sell 110 octane and get some and mix it half half. I can tell a diffrence, But it isnt neccassary to run that high octane. It does smell good when burnt also. Like wireman said it all depends on your engine.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- kzz1king
wireman wrote: Its the actual cranking compression numbers you need to worry about and it has a lot to do with cam lift and duration and cam timing.
So how does one get these numbers and how do I use them when I get them? I cannot remember what I degreed the cams to. Cams are a mild drop in. My hearing is not good enough to pick up pinging. Bike runs great and I want to keep it that way
Wayne
- les holt
- Thank you received: 288
4thekz, I hope turbo blue is better in your area, worst fuel I've ever seen! Everybody had problems with it around here to the point they quit selling it, nobody would buy it.
Les
- wireman
Get a compression tester from auto parts store would be first thing if bike is up/runningkzz1king wrote:
Wayne
- Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- mark1122
- Keep twisting it
- Thank you received: 109
a Dyna2000 . it has an electronic advance curve that can help if u have a ping.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- mtbspeedfreak
- Thank you received: 36
I know the mechanics behind each method, just trying to save myself a few bucks.
2000 ZRX 1100
1976 KZ 900- Daily Driver
