- Thank you received: 3
Bummed out.
- gixxerkidd03
13 Sep 2012 04:15 #548414
by gixxerkidd03
1981 KZ750e
Bummed out. was created by gixxerkidd03
i almost completed my 82 750e cafe build when i was changing the spark plugs when i noticed cylinder #3 threads were trashed. now what? pull the head and take it to a machine shop?im not so happy. i also have a second question which im sure has been asked a millions times before. could i put a 750 gpz head on my 750e?if so are there any concerns other then air/fuel and what years are compatible?im looking to possibly do a rebuild or big bore now if im cracking the engine apart. theres no good way to tap or rethread the spark plugs hole with the head on right?thanks
1981 KZ750e
- Thank you received: 2098
13 Sep 2012 05:37 - 13 Sep 2012 05:40 #548416
by Patton
Replied by Patton on topic Bummed out.
Cross-threaded or completely stripped bare of thread?
Where thread remains, but impossible to get the plug " started" into the hole, the threads may sometimes be restored by using a "back tap" (also known as a "reverse tap") tool to re-cut the damaged portion of the thread.
A back-tap tool begins the re-tap at the deep end of the spark plug hole where the thread often remains okay.
Once started, the re-threading progresses upward and on through the cross-threaded upper part of the hole. Thereby restoring and re-aligning the threads.
Such tool may be used without removing the head, or any other dis-assembly.
Last edit: 13 Sep 2012 05:40 by Patton.
- gumby prichard
- Thank you received: 1
13 Sep 2012 12:24 - 13 Sep 2012 12:24 #548452
by gumby prichard
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
Replied by gumby prichard on topic Bummed out.
I have heard a product called HELICOIL works wonders. it is actually what looks like a threaded bushing. the threads on the outside are tapered so that as you screw it in they get tighter and tighter...the threads on the inside will be the original size of the hole that stripped.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
Last edit: 13 Sep 2012 12:24 by gumby prichard.
- baldy110
- Thank you received: 512
13 Sep 2012 13:10 #548455
by baldy110
Replied by baldy110 on topic Bummed out.
I've installed helicoil inserts into stripped out spark plug holes without removing the head. I put the piston at TDC and use a lot of grease on the tap to catch the metal particles. After the repair I tape a straw to a shop vac and stick into the spark plug to remove the remainder of whatever fell into the hole.
- gixxerkidd03
13 Sep 2012 15:06 #548469
by gixxerkidd03
1981 KZ750e
Replied by gixxerkidd03 on topic Bummed out.
thanks for the advise everyone. i will let you know what i decided. im moving the bike on a trailer in a few days so i may decide swing it by a local shop to see what they have to say about it. anyone know anything running a gpz or a more aggressive cylinder head on my 82 750e?
1981 KZ750e
- MFolks
- Thank you received: 540
13 Sep 2012 18:19 #548502
by MFolks
Replied by MFolks on topic Bummed out.
- steell
15 Sep 2012 13:01 #548847
by steell
Replied by steell on topic Bummed out.
Yes you can use a GPz750 head on your 750E, direct bolt on.
May be worth 1-4 hp.
