kz1000st tachometer
- motomensch
12 Sep 2012 18:44 #548294
by motomensch
When you stop laughing, the joke's on you!
kz1000st tachometer was created by motomensch
My Tach on my 17979 KZ1000E1 is kaput and I am having difficulty finding a replacement. One guy on e bay has one and will mail to me but the manual says they are first, non repairable, second oil filled and should not be turned over. What are the odds of that with the Post Office. Has anyone had experience with mailing these gauges? Does anyone know of a different tach that would work at the same ratio as the gear drive on my cable? I have new gears and cable and they seem to be working OK. Any and all help appreciated, or direction to a replacement tach.
Thanks
Thanks
- Roadflyer
- Thank you received: 13
12 Sep 2012 20:09 #548304
by Roadflyer
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
Replied by Roadflyer on topic kz1000st tachometer
i had the tach apart on my 1979 shaftie and never saw any oil, just a regular tach with a fuel gauge inset.
- RonKZ650
- Thank you received: 240
13 Sep 2012 00:19 #548388
by RonKZ650
Replied by RonKZ650 on topic kz1000st tachometer
Yea, they are not oil filled or anything different than any other KZ tach other than being standard KZ1000ST part, which is always unique to the model. I would guess with 99% certainty you can use any KZ1000,750, 650, 550 ect tach and it will work just fine. Just won't look original. Nothing special about the KZ1000E, just used a cable from the engine to the tachometer just like all the rest did back then.
- motomensch
13 Sep 2012 12:34 #548454
by motomensch
Replied by motomensch on topic kz1000st tachometer
So does anybody have any ideas or information why the factory shop manual say it is oil filled and not to turn it over? Also, are they repairable?
- pete greek1
- Thank you received: 185
13 Sep 2012 13:30 #548458
by pete greek1
Replied by pete greek1 on topic kz1000st tachometer
[attachment:1]C:\fakepath\DSCF1635.JPG[/attachment]
I had mine restored at Z-Resto Gauge restoration, you can call them up & ask if your gauge is oil filled or not, I believe you should"nt leave any gauges upside down or on thier side, for any length of tine....Pete
- pete greek1
13 Sep 2012 14:57 #548466
by pete greek1
had to resize pic.
Attachment DSCF1651.JPG not found
had to resize pic.
- Bozo
- Ride it like u stole it
- Thank you received: 105
15 Sep 2012 04:48 #548794
by Bozo
Replied by Bozo on topic kz1000st tachometer
The oil they talk about is the dampening fluid used on the spindle shaft, it is a small container on the shaft, it has fluid to prevent the needle from freely jumping around. My Z1r had a fluid leak when I transported it interstate, unfortunately I now have a stain on the tacho, it still works ok and can be replaced using a thin needle. sorry about the poor picture, you can just make out the dark shadow on the bottom face.
Attachment DSC09264.JPG not found
- Bozo
15 Sep 2012 04:54 #548796
by Bozo
here's a better picture, all cable speedos and tacho have this fluid, you can put a "THIS WAY UP" label on the box I'm sure all delivery services take note of it
Attachment DSC09265.JPG not found
- motomensch
15 Sep 2012 10:20 #548825
by motomensch
Thanks for all the information, I ordered one on ebay and will see what happens, doesn't have to-travel far, just from Texas to New Mexico.
- Bozo
16 Sep 2012 00:51 #548983
by Bozo
you should be right, mine was being recalibrated and I think it went by road (Australia- East /west = >4000kms) in the heat. I did refill the fluid but by then the facia had stains - bugger.
