Advacing Of Ignition
- 4TheKZ1000
10 Sep 2012 22:36
Forum....with the auto advancer, was there ever a performance upgrade for advancer weights....or a trick that would improve upon stock ignition advance?
Seems like all other engine combos are able to be tricked out....my racing go carts advance was adjustable along with the snow mobile engine...hell on the old cars before elec ign....you could change springs to quicken the ign adv.
I would ass-u-me that stock is it for the KZ!
Thanks
Thanks
- Tomolu5
Re: Advacing Of Ignition
10 Sep 2012 22:51
Electronic ignition
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
- 4TheKZ1000
10 Sep 2012 23:18Tomolu5 wrote: Electronic ignition
I have a dyna-S.....still has the advance weights....right?....still advances, just becouse you have elec ign....dosent mean you dont advance ign anymore? :dry:
- Motor Head
10 Sep 2012 23:23
The mechanical advance is for the street. Are you dragging yours? If so you can set it to total degrees for max power, and just put a weak spring in it so its easier to start.
If street use, keep the advance, but you can re-curve it. Quicker to total will depend on compression/ cylinder pressure and fuel octane. Total advance is something to set for peak power and not fuel economy still.
- MDawnz1
10 Sep 2012 23:25
I run a dyna 2000 system system on my 74 Z1.
It gives me 16 curves and 16 rev limits.
I run the closest to stock settings.
BUT with the stock points........
A spare advancer .........
A drop of solder on the weights will get your advance in quicker......
File the slots a little longer will be more advance .........
You can do anything you want to your curve .
LOTS of experimentation .
Just dont hurt it messing around .
1974 Z1a, still 903
The following user(s) said Thank You: 4TheKZ1000
- 4TheKZ1000
10 Sep 2012 23:29
Thanks Motor Head
Street use.
10.25 to 1
Running turbo blue 110 octane
Im not looking for MPG just HP.
Street use.
10.25 to 1
- RonKZ650
11 Sep 2012 00:14
Old days guys used to just weld the ignition at full advance commonly. These were drag bikes. On the street I guess there is a reason for advance at certain RPM.
- bountyhunter
11 Sep 2012 03:44A slightly lighter spring will also advance the curve faster.MDawnz1 wrote: I run a dyna 2000 system system on my 74 Z1.
- Tomolu5
11 Sep 2012 22:09MDawnz1 wrote: I run a dyna 2000 system system on my 74 Z1.
This is what I meant by "electronic" sorry, should have been specific.
Mine:
