- Thank you received: 1
Back-pressure and shifting
- KZCool
10 Sep 2012 14:14 #547834
by KZCool
1976 KZ750 hardtail
Back-pressure and shifting was created by KZCool
Can lack of back presure have an affect on how a bike shifts? My 750 has some funny ticks with the shifting like not wanting to fully shift into first unless I really pound it down, or not clicking all the way through a gear going up. I noticed when I added baffles before it didnt seem near as bad. Just a shot in the dark.
1976 KZ750 hardtail
- TeK9iNe
- What did you do!?!
- Thank you received: 28
10 Sep 2012 14:38 #547836
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Back-pressure and shifting
Anythings possible man! lol
You may need to adjust you're shifting routine to include not snapping the throttle closed as much during a shift - this is when backpressure/vacuum spikes its highest.
Maybe avoid clutchless shifts or slow your shift slightly.
Always make sure to firmly engage every gear with the shift pedal, as not doing/miss shifting increases wear.
And use a good motorcycle wet clutch approved oil of the correct weight.
Cheers!
Cheers!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- baldy110
- Thank you received: 512
10 Sep 2012 22:29 #547913
by baldy110
Replied by baldy110 on topic Back-pressure and shifting
No, baffling will not effect how the tranny shifts. When was your last oil change? I notice as the oil gets really dirty it tends to make the tranny shift harder.
- KZCool
11 Sep 2012 01:08 #547959
by KZCool
1976 KZ750 hardtail
Replied by KZCool on topic Back-pressure and shifting
Thanks for the advice guys. I actually planned on doing an oil change tomorrow. Hope it helps
1976 KZ750 hardtail
