- Thank you received: 4
Replacement baffle for a Mac canister?
- richrand
06 Sep 2012 19:01 #547126
by richrand
Replacement baffle for a Mac canister? was created by richrand
No eBay APP ID and/or Cert ID defined in Kunena configurationMy bike came with a Mac canister system with the overlapping-tube street baffle. It really sounds terrible to me and I'm looking to lower the volume and add a touch more back pressure. I've been told that because of the overlap-tube design I can't use any glass packing. I've tried but it doesn't seem to work well and chocks up my motor something fierce. The header is in very good shape and I'd happily keep it for now if I could figure out a better way to tune it.
I came across this:
Think its worth a try? I also read somewhere that a Kerker K2 baffle will fit, but they're quite expensive. Any advise as to how I can improve this system? Thanks!
(my user pic shows the exhaust system)
I came across this:
- Thank you received: 1656
06 Sep 2012 19:52 - 22 Jan 2013 23:53 #547136
by martin_csr
Replied by martin_csr on topic Replacement baffle for a Mac canister?
Someone here on KZR slid a tractor muffler inside of his aftermarket can & secured it w couple of screws.
A real tractor, not an HD. Both topics have photos. Tractor muffler???
The tractor muffler guy then came up with this solution to address a back pressure issue:
Neat trick for Mac headers
Last edit: 22 Jan 2013 23:53 by martin_csr.
- richrand
07 Sep 2012 15:44 #547317
by richrand
Replied by richrand on topic Replacement baffle for a Mac canister?
Slam dunk, man. Thanks.
- MFolks
- Thank you received: 540
07 Sep 2012 16:20 #547319
by MFolks
Replied by MFolks on topic Replacement baffle for a Mac canister?
