- Thank you received: 1
VALVE CLEARANCE TROUBLE AFTER REBUILD ON 78 KZ650
- mrscherer
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- gumby prichard
also if you can move the bucket easily while lobes arepointed away from valves that would mean your clearence is most likely between .001 and .005
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- mrscherer
- mrscherer
- OldSchoolZ
- Thank you received: 33
.038mm is ---.0014 inches
.038mm divided by 25.4= inches
inches multiplied by 25.4 = millimeters.
Example,,,if you had a 265 shim and went to a 260 you are installing a smaller shim for more clearance.
265-260 is roughly .002 more clearance
If you had 265 and it went 263 (half sized shim not too uncommon) thats about .001 approximately.
Just remember, the smaller number on shim will give you more valve clearance.
Remember, don't work on your bike so much you never ride it.
- Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- bountyhunter
- Thank you received: 337
you really need gauges down to .001"mrscherer wrote: Yeah, I can spin the buckets easily. Apparently I have been measuring in inches when mm is what is called for but it's still too tight for .038mm which is my smallest gauge.
www.bing.com/shopping/bike-master-feeler...er%20gauge&FORM=HURE
- baldy110
- Thank you received: 512
