1980 KZ550 LTD stop light
- BLT
05 Sep 2012 12:48
Hi, I am new to the forum and just bought a KZ550 LTD. After riding for half a day, both the stop lamp and the oil light in the instrument cluster turned on.
Is the oil light on because of oil overheating? Or incorrect oil viscosity?
The stop lamp lights up every time I apply the brakes, but later in the day the stop lamp was on continuously. Might this be a low gas level light as well?
Thanks for your help.
B
B
- MFolks
Re: 1980 KZ550 LTD stop light
05 Sep 2012 13:12
The oil level should be visible in the window of the clutch housing. Some models have a high and low level marks.I would not run the engine until you determine if the oil sender is acting up or because the oil is low.
As for the bake light indicator, again, some models have a sensor that turns on the warning light everytime the brake is applied, but since your's is now always on, I'd remove the brake/running light bulb(s) in the rear light and see if they are burned out/broken. I believe they are # 1157 dual filiment bulbs.
- KZQ
- Administrator
05 Sep 2012 13:13BLT wrote: Hi, I am new to the forum and just bought a KZ550 LTD. After riding for half a day, both the stop lamp and the oil light in the instrument cluster turned on.
B
Hi and welcome to KZR!
I doubt that the incorrect weight of oil would fail to build enough pressure to trip the sensor. Can you swap it out with another sensor?
For the brake light Check the switch attached to the rear brake to see if it is retracting after you release the brake.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
Last edit: 23 Jan 2013 00:16 by martin_csr.
