does a 82gpz550 have rubber motor bushings
- kikonlyj
05 Sep 2012 00:20 #546741
by kikonlyj
does a 82gpz550 have rubber motor bushings was created by kikonlyj
i would like to know 2 things first does the 82 gpz550 have rubber bushings installed where the motor mounts attach to engine ? also would like to know of any custom frames , hardtail chopper style for this motor , i have found some for the 750 but not the 550
- loudhvx
- Thank you received: 1616
05 Sep 2012 03:45 #546773
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic does a 82gpz550 have rubber motor bushings
I don't think the gpz550 motor had rubber bushings until 1984 ZX550 A.
I don't know of any frame you can buy, but plenty of people have modified the KZ550C frames into hardtails, choppers, and bobs. The gpz 550 motors fit into the ltd frames easily, but you will need to keep the oil cooler.
A standard KZ motor is better suited to that type of bike, though, so I would recommend a non-gpz motor, plus they are more plentiful, and probably in better condition.
1981 KZ550 D1 gpz.
Other links.
The following user(s) said Thank You: kikonlyj
- Thank you received: 2829
05 Sep 2012 10:00 - 05 Sep 2012 10:01 #546805
by 650ed
Replied by 650ed on topic does a 82gpz550 have rubber motor bushings
A GpZ chopper? :blink: :blink: Why not get an ELR for that mod? :laugh:
Last edit: 05 Sep 2012 10:01 by 650ed.
- kikonlyj
16 Sep 2012 20:23 #549126
by kikonlyj
Replied by kikonlyj on topic does a 82gpz550 have rubber motor bushings
ELR ? what is that , also this bike is being built to a chopper to conform to rules to race coast to coast . last year i had a larger budget but this year its a low buck build
