Another engine noise question?
- bobski911
Could it be a wobble in the exhaust cam and thats why it is every 3 seconds?
Thanks
- moneypit
- Thank you received: 35
2-76 kz900
St Paul MN
- bobski911
Thanks
- wireman
- Thank you received: 299
- bobski911
wireman wrote: Pull the valve cover off and run it on the center stand to make sure its getting oil and to see if you notice anything strange
ok, just to clarify. Will I need to do this somewhere like outside? will oil splash all over the place? I always wondered about running the bike with the valve cover off.
- bobski911
Thanks
- wireman
What year of bike is it?
- bobski911
Thanks
- sham
- Thank you received: 1
- wireman
That guiide sets the location of cams Im pretty sure,Im used to older motorsbobski911 wrote: Its an 83, and it does have a cam guide on the top of the cover. Will it really be a big problem? what if I tightened the cam adjuster a little more while the cover is off? Just an idea, I really dont know.
Thanks
