- Thank you received: 512
O-ring size
- baldy110
31 Aug 2012 21:04 #545948
by baldy110
O-ring size was created by baldy110
Anyone know what the o-ring size is for the KZ1000J cylinder head. The ones that are at the four corners between the head and cylinder. I know they are 18.5mm around but I need to know the thickness. Thanks
- OnkelB
- Thank you received: 80
03 Sep 2012 18:45 #546443
by OnkelB
77 KZ 650 B1, 82 GPz 1100 B2.
Replied by OnkelB on topic O-ring size
Thickness is 3 mm - part no. is 92055-1148, Kawasaki.com lists them as still active.
They're pricey though (as you probably already know), I've seen them on various webshops for 6-8 bucks a piece. :S
- Motor Head
- Thank you received: 391
03 Sep 2012 18:59 #546444
by Motor Head
Replied by Motor Head on topic O-ring size
