- Thank you received: 299
Rebuilt, getting mixed reviews about the engine
- wireman
Well tney dont seem to mind the busa brothers babgin em off the pistons at 16,000 rpms! :woohoo:oldzed wrote: Just to add something.
This motor is giving decent compression considering it is still "dry"
I wopuld be tempted to add a little oil to each cylinder and retest.
I think you would see an improvement in the readings.
A leakdown test is to see where air is escaping when compression is low.
Lots of engines I have tested over the years have failed leakdown tests until they have been run.
In the old days when we ground in valves we would finish by giving the valve a sharp tap to fully
seat it . If you did not do this they were harder to start till the valves go bangerd into the seat.
DO NOT TAP ANY MODERN 16v TYPE VALVES. THEY CAN BE DAMAGED DUE TO THE MATERIALS USED
- LarryC
Attachment 260481_453872701331796_622265658_n.jpg not found
A leak down and compression test will support each other...not be contrary to each other.
Larry C.
- silentchris
Speed is only a question of money. How fast do you wanna go?
1978 kz1000 ltd
Hailing from the wild suburbs of our nations capital
- OldSchoolZ
- Thank you received: 33
But rule of thumb is, dont use the bolt on the end of the crankshaft because its only an 8mm bolt and with much compression it can break that bolt off easily. Starter or kick starter only.
You can use the 19mm or 17mm (cant remember)on the end of the advancer to turn if your spark plugs are removed and you need to turn the motor
Remember, don't work on your bike so much you never ride it.
- roy-b-boy-b
- Thank you received: 103
