Timing chain
27 Aug 2012 21:25 #545168 by built408
Timing chain was created by built408
I have a newbie cam chain question, I have some noise in my engine a bunch of people say its the cam chain. So im going to try to adjust the chain I have the origanal owners manual and it has the instructions on how to do this but it will be my first time. Any one have any advice and how will I know if it worked. So I just loosen the bolt and re tighten it? Seems a little vague and easy. Also im going to get the valve clearance checked by a professional does any one have a ball park price I should pay to make sure Im not getting ripped off. Thanks.
1978 KZ1000 A2A with MKII body you know you like it
  • 4TheKZ1000
  • Visitor
27 Aug 2012 21:29 #545169 by 4TheKZ1000
Replied by 4TheKZ1000 on topic Timing chain
I would say cam chain idler before chain
27 Aug 2012 21:50 - 27 Aug 2012 21:55 #545178 by built408
Replied by built408 on topic Timing chain
Sorry but what is cam chain idler? Is that the chain tensioner with the lock nuts?
Thats the gear at the top. What you think that may have went bad I never thought of that.
Last edit: 27 Aug 2012 21:55 by built408. Reason: I figured it out
  • 4TheKZ1000
  • Visitor
27 Aug 2012 21:55 - 27 Aug 2012 22:00 #545179 by 4TheKZ1000
do you have a correct service manual for your bike??? if not buy one.
this might not be your model or year but you can see all the moving parts.
www.cmsnl.com/kawasaki-1978-kz1000-a2a-k...t/66330.html#results
Last edit: 27 Aug 2012 22:00 by 4TheKZ1000.
27 Aug 2012 22:01 #545180 by built408
No I just have the owners manual I've ben looking on this site to see which one is best what service manual do you recommend. Thanks for the help
  • 4TheKZ1000
  • Visitor
27 Aug 2012 22:02 #545181 by 4TheKZ1000
we the forum love to help out but you really need to purchase or download a manual.
what year and model do you have
27 Aug 2012 22:03 #545182 by MFolks
Replied by MFolks on topic Timing chain
27 Aug 2012 22:04 #545183 by 650ed
Replied by 650ed on topic Timing chain
built408 wrote: I have a newbie cam chain question, I have some noise in my engine a bunch of people say its the cam chain. So im going to try to adjust the chain I have the origanal owners manual and it has the instructions on how to do this but it will be my first time. Any one have any advice and how will I know if it worked. So I just loosen the bolt and re tighten it? Seems a little vague and easy. Also im going to get the valve clearance checked by a professional does any one have a ball park price I should pay to make sure Im not getting ripped off. Thanks.
"So I just loosen the bolt and re tighten it?"
That's not how you do it. You may want to re-read the manual. If it simply says "loosen the bolt and re tighten it" get the Kawasaki Service Manual. Before loosening the bolt you must set the crankshaft at a specific point. Ed
  • 4TheKZ1000
  • Visitor
27 Aug 2012 22:06 #545184 by 4TheKZ1000
:dry:
27 Aug 2012 22:10 - 27 Aug 2012 22:20 #545186 by built408
Thanks I've been looking all over the internet for like two weeks for a non virused out downloadable version but cannot find one I think I will just buy the clymer. Do you guys recommend the clymer or something different. Thanks a bunch Guys. Also I know thats not all to it but i dont need to list all the steps. But when it comes down to it all you do after you use a 17mm wrench,turn the crank shaft clockwise about two turns,and align one of the t marks on the timing advancer with the timing mark above the advancer . Loosen the chain tensioner locknut and bolt ( with the bolt loose,a spring inside takes up slack automatically)....etc I just wasent sure if I should do different or any advice
Im not a bike teck but im not stupid ed
Last edit: 27 Aug 2012 22:20 by built408. Reason: k
27 Aug 2012 22:18 #545188 by 650ed
I recommend the Kawasaki Service Manual (not Clymer or Haynes). They are usually available on eBay, just be sure to get one that covers your exact year/model as there are differences. Ed
  • 4TheKZ1000
  • Visitor
27 Aug 2012 22:41 #545193 by 4TheKZ1000
650ed wrote: I recommend the Kawasaki Service Manual (not Clymer or Haynes). They are usually available on eBay, just be sure to get one that covers your exact year/model as there are differences. Ed
+1 with Ed
