What is this/what is it for? '78 KZ650 question
- KinkJayRoe
26 Aug 2012 18:57 #544900
by KinkJayRoe
What is this/what is it for? '78 KZ650 question was created by KinkJayRoe
While doing some work on my '78 KZ650 today, I noticed this build up on only a particular part of the bike. I followed it back to the pictures below which looks like some sort of valve that is supposed to be threaded shut. Am I just missing the cap, or is it supposed to be open? It is located in the front of the engine directly above the 2 exhaust opening from the right side of the bike.
- Rainman
- and a little Kaw shall lead them
- Thank you received: 75
26 Aug 2012 19:07 #544901
by Rainman
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
Replied by Rainman on topic What is this/what is it for? '78 KZ650 question
Welcome KinkJayRoe, that is where the tachometer cable connects.
Jim
Quincy,IL
- Del_Herring
- Thank you received: 29
26 Aug 2012 19:07 #544902
by Del_Herring
1983 KZ750-N2 Spectre
Replied by Del_Herring on topic What is this/what is it for? '78 KZ650 question
Thinking that's the tachometer drive that everyone says always leaks. I have a spectre, so I don't have one, but I'm pretty sure someone else will be along shortly to confirm that's what it is.
- MFolks
- Thank you received: 540
26 Aug 2012 19:16 #544904
by MFolks
Replied by MFolks on topic What is this/what is it for? '78 KZ650 question
Yep, the tach drive connection. If it's open like this, you'll be having oil come out when the engine is running, possibly getting onto the exhaust, making a smell of hot oil & smoking.
- KinkJayRoe
26 Aug 2012 20:57 #544925
by KinkJayRoe
Replied by KinkJayRoe on topic What is this/what is it for? '78 KZ650 question
awesome, makes sense now. Thanks a lot!
- pete greek1
- Thank you received: 185
26 Aug 2012 21:46 #544931
by pete greek1
Replied by pete greek1 on topic What is this/what is it for? '78 KZ650 question
I"m thinking it should"nt leak, even if the tach cable is"nt connected, ...you might want to replace the "O" rings in the tach housing before you put a new tach cable, so you dont have oil leaking down your engine, and onto your exaust ...Pete
- Thank you received: 2829
26 Aug 2012 22:30 #544937
by 650ed
Replied by 650ed on topic What is this/what is it for? '78 KZ650 question
As stated the tach cable hooks up there. This shows the 2 ends of the cable:
Attachment tachcable.jpg not found
