Knocked a tube off of my '80 KZ440
- time440
25 Aug 2012 10:37 #544673
by time440
1980 KZ440B
Knocked a tube off of my '80 KZ440 was created by time440
Hey all,
I managed to knock this adapter and piece of hose off of my bike while cleaning it last night... The rubber doesn't stand up well after 32 years. I just cannot figure out where it goes. I looked through both the Haynes manual and the Kawasaki service manual and neither appear to show this piece.
It's not from the fuel petcock, the carb drain lines, or the drain line from the airbox. It also is not a vent hose for the battery. I went so far and disconnecting the airbox so I could try to see between the two carbs, but to no avail... Any other riders out there who'd be willing to take a look on their bike to see where it goes?
Attachment 0825020144.jpg not found
1980 KZ440B
- peter1958
- Banned
- Thank you received: 198
25 Aug 2012 10:41 #544674
by peter1958
Replied by peter1958 on topic Knocked a tube off of my '80 KZ440
It sure looks like a line too the carbs but could be an old one that was dropped when a new one was replaced if it runs and doesnt leek gas
The following user(s) said Thank You: time440
- time440
25 Aug 2012 10:49 #544676
by time440
1980 KZ440B
Replied by time440 on topic Knocked a tube off of my '80 KZ440
Thanks for replying so quickly.
My first thought was a gas line too... it's hard to tell from the crappy photo resolution, but one end of the rubber is all cracked, so I'm assuming that it was attached to the T fitting. The other end is not cracked, which is the reason I'm guessing it's for venting.
As far as I can tell from looking at the manuals, the only place that uses ANY T fitting is the fuel line going into the carbs, and that is in place and not the same style as this piece anyway. Can you think of anywhere else that would be vented by a tube?
1980 KZ440B
- peter1958
- Banned
25 Aug 2012 10:51 #544677
by peter1958
does the bike run?
- time440
25 Aug 2012 11:09 #544679
by time440
1980 KZ440B
Unfortunately it's torn apart right now; I had to take out the battery box and other things to move the airbox so I could look at the carbs more closely. I should probably just put it back together and check that out.
1980 KZ440B
- wireman
- Thank you received: 299
25 Aug 2012 12:11 #544693
by wireman
Replied by wireman on topic Knocked a tube off of my '80 KZ440
Somebody capped off one end of it with a cap,id start with vacuam lines.
Maybe check emissions stuff on top of motor under gas tank
