Valve adjustment and oil change on an 82 GPz550
- marsracer
24 Aug 2012 16:23 #544540
by marsracer
Valve adjustment and oil change on an 82 GPz550 was created by marsracer
Where would I find the procedure and specs for doing a valve job? Is it a hard job? Is there a web site that has this information or does some one here know the specs? This thing runs great when you first get on it. But after a few miles, and shutting it off and sitting for a while and getting back on it runs like crap. I can't adjust the idle properly. If I turn the idle up it shoots up to 3 to 4000 rmp. But if I turn it ever so slightly back, it wants to idle at 300 and not run so great and die.
- marsracer
24 Aug 2012 16:27 #544541
by marsracer
Replied by marsracer on topic Valve adjustment and oil change on an 82 GPz550
And about the oil change, do I have to pull the exhaust off to get the oil filter out and in? Or should it fit right up in there?
- Del_Herring
- Thank you received: 29
24 Aug 2012 16:34 #544544
by Del_Herring
1983 KZ750-N2 Spectre
Replied by Del_Herring on topic Valve adjustment and oil change on an 82 GPz550
have you checked the filebase to see if there's a downloadable manual for your bike here? (Button on top right of page). For oil, if you have a 4-1 exhaust, they pretty much all end up having to be removed to get to the oil. The stock units on most of the KZs don't require removal to get the oil changed, I would guess, but cannot garauntee, that it's the same for the GPz. If the oil filter mount is directly over the exhaust, you'll have to drop the exhaust, should find out pretty quickly once you get under there and try.
- marsracer
24 Aug 2012 17:00 #544551
by marsracer
I've got 4 to 2 exhaust. But didn't know if I have to pull the exhaust all the way out of the head ot if it comes apary. If I pull it out of the head, are there little copper rings that need to go back up in there as an exhaust gasket? I don't want to put too much money in to this thing. I'm selling it and am barley going to break even if I sell it as is.
- Del_Herring
24 Aug 2012 17:15 #544553
by Del_Herring
There's copper gaskets in there, but I've typically been able to reuse them, mine usually just end up staying on the head unless I get a pick in there to pull them out. Might take them out and clean them up to make sure you get a good seal surface, but I've rarely needed to replace them to get a good seal. Depending on their condition it may or may not work for you. Even if it comes apart in the middle, you'll have to get it off the head to seperate them, so if they're blocking the oil, they'll have to come off one way or another.
- marsracer
26 Aug 2012 17:28 #544888
by marsracer
Okay. Now. is it hard to adjust the valves?
- MFolks
- Thank you received: 540
26 Aug 2012 17:38 #544891
by MFolks
Replied by MFolks on topic Valve adjustment and oil change on an 82 GPz550
If your valve shims are under the "Buckets"(followers), the cams have to come out to adjust them(usually thinner shims as the valves and valve seats wear).
Manuals(Some of these websites sell used manuals,just ask)
www.repairmanual.com
www.manualsnmore.com
www.midwestmanuals.com/
www.books4cars.com/
www.repairmanualclub.com/motomanuals/
moto-manuals.com/
www.e-classicbike.com/
www.books4cars.com/
moto-manuals.com/
