KZ900 Stripped Spark Plug Hole
25 Aug 2012 11:20 #544681 by Old Man Rock
Replied by Old Man Rock on topic KZ900 Stripped Spark Plug Hole
The top video Rocks!... ;)
We use Crisco cooking "White" shortening grease with exceptional results at work. Our machinist taught me that trick plus helps capture the shavings when tapping aluminum or steel... Have used other lubricants (WD-40 for example) and have broken taps with it... :angry:
I'm with Ed on this one, pull the head for now way in hell would I perform this while on the bike.
Way too many variables to go wrong...
1) Shavings in cylinder... :pinch:
2) Alignment inaccuracies of tooling due to frame tubing and such... :whistle:
I know, laugh all you want but the crap is magic for tap... B)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
The following user(s) said Thank You: MDawnz1
  • BlackZ1R
  • Kawasaki in my blood
25 Aug 2012 14:02 - 25 Aug 2012 14:04 #544718 by BlackZ1R
Replied by BlackZ1R on topic KZ900 Stripped Spark Plug Hole
BigK, you can do it without removing the head. Like was stated, if any chips do fall into the cylinder and get trapped or can't be retrieved, it is soft aluminum. It will be minute, and will easily pass out of the engine with no damage.
We use tapping wax, it rarely ever comes off of the tap while tapping. Never had a problem with any I've done.
If you do pull the head, don't pull the jug to replace the base gasket unless it is leaking or you disturb it when removing the head.
This is the stuff: :)
www1.mscdirect.com/cgi/NNSRIT2?PMAKA=05651583&PMPXNO=1745024
EDIT: never tried the Crisco OMR. I'm sure wifey would give me some strange looks if she caught me with the can :laugh:
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
Last edit: 25 Aug 2012 14:04 by BlackZ1R.
25 Aug 2012 17:13 #544746 by BIGKEVIN
Replied by BIGKEVIN on topic KZ900 Stripped Spark Plug Hole
I tried find the Time-Sert rethreading tool at the local auto parts store, but could not find it. I found thread-safer and fix a thread. Are those good or should I find Time-Sert ? Am I going to have to order Time-sert from online ? Is tehre are particular part number for the KZ 900 ?
1976 KZ900
2006 ZX6R
10 Sep 2013 20:37 #605898 by kawman66
Replied by kawman66 on topic KZ900 Stripped Spark Plug Hole
fix a thread is heli coil avalible at orileys
75 z1b
76 kz900ltd
76 kz900
76 kz900-1500
77 kz1000ltd
my drinking team has a racing problem
11 Sep 2013 11:54 #606001 by Cynjut
Replied by Cynjut on topic KZ900 Stripped Spark Plug Hole
O'Reilly has a website. I think you can find out if your local store carries these from that.
The larger NAPA stores (the local "warehouse" store, if you have one) should have both Helicoil and Timesert.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
