I need help finding torque specs for a 1979 kz 650
  • Derigo
  • Derigo's Avatar Topic Author
22 Aug 2012 15:33
#544118
head torque
  • martin_csr
  • martin_csr's Avatar
Re: I need help finding torque specs for a 1979 kz 650
22 Aug 2012 16:33
#544130
Did you look in the filebase to see if there's a manual?
The following user(s) said Thank You: Derigo
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
22 Aug 2012 17:24
#544137
IIRC there are 12 cylinder head nuts and 2 bolts (in the cam chain tunnel.
The nuts should be torqued to 3.5 to 4.0 Kg/m or 25.0 to 29.0 ft/lbs
The 2 bolts should be torqued to 2.2 to 2.8 kg/m or 16.0 to 20.0 ft/lbs
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
