what octane?
- cherokeekid58
Hahaha and i thought my JEEP addiction was bad; my Kz addiction is just as bad!!!
www.kzrider.com/filebase/cat_view/102-1982 ,
- Thank you received: 2098
Regular grade gasoline, provided that using it doesn't cause the motor to "ping" under load.cherokeekid58 wrote: I never figured it out. So ill ask you good folk. What octane gas should i be running in my 82 kz750 4cyl?
But in any event, if a motor is pinging, would assure ignition timing is correct, regardless of the grade of gasoline being used.
- Del_Herring
- Thank you received: 29
Like patton says, if you get any pinging, go up an octane rating, but it may be indicative that something else is a little out of whack, timing, or maybe excessive carbon buildup somewhere (the carbon holds heat and can cause pre-ignition).
1983 KZ750-N2 Spectre
- cherokeekid58
- Del_Herring
- cherokeekid58
- mtbspeedfreak
- Thank you received: 36
2000 ZRX 1100
1976 KZ 900- Daily Driver
- bountyhunter
- Thank you received: 337
- zukdave
- Thank you received: 229
and it's hot out it may ping from a lean miss fire
then you put in some premium the pingging stopped
then you think you need the better gas
when you realy need to fix the carb.'s
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- OldSchoolZ
Octane ratings and what they refer to has been misunderstood by most people for YEARS.
Most people think a higher octane fuel is a more flammable quicker burning fuel, but it isn't.
The lower the number of octane the FASTER the fuel burns. The higher the number of octane the SLOWER it burns.
When an engine has high compression, compressed fuel with burn more quickly. And since detonation is a combustion which burns so fast it flashes and only distributes the explosion to one side of the piston and not both sides of the piston equally. This is the knock you hear.
On high compression you need a fuel that will burn more slowly and allow the explosion to distribute its load evenly across the piston resulting in no detonation or ping.
I hope this helps the guys that didnt really understand the full concept.
Remember, don't work on your bike so much you never ride it.
- cherokeekid58
Cheers
Jason
