Help with non running kz650
- thoshi64
I've been having a world of trouble with a project bike I bought and it's getting to a point where I'm just getting depressed with this project and want to get rid of it. I've put in about 700 - 800 total. I'll try to explain what I know so far and hopefully you can find something.
To begin with, the tank had a kreem lining that was falling apart and I got rid of it along with the rust and have successfully gotten it clean, but for some reason when putting the gravity petcock on, the gas won't flow fully into the line. I have a clear line so I know gas is getting to the carbs but the line isn't full all the way to the tank with gas and I'm fairly sure there is a sufficient amount of gas. I cleaned the petcock and am sure there is nothing blocking the petcock in the tank. Not sure what's going on there.
The bike won't start. When I got it, the first thing I did was clean the carbs making sure to clear all the small jets. I did not check to see if the jets were the correct size for stock. The airbox was missing so I ordered some cheap/chinese air filters/pods of ebay. Is this a problem? or do they work fine? I did re-jet the carbs correctly. From there I reset the points correctly (pretty sure) and set the gap using a feeler gauge. Now I haven't been able to get any combustion going at all. I put in new spark plugs and have checked them, they have a nice large spark to them.
Some things I noticed, the cylinder closest to the kickstand seem to be drenched with gas when I pulled the spark plug out while the opposing side was relatively dry. When I'm turning over the engine, I can feel some air right at the connection between the carb and the boot. Is this a vacuum leak? The battery will turn the engine over using the starter at 13 V but around 12.5 the starter will no longer work (checked with multi meter). When I'm trying to start it, I start it in neutral. Should I be using a different gear? I've also tried spraying some starter fluid on the pods and in the engine through the spark plug hole on separate occasions and nothing still.
Can you please help me diagnose this project as I would like my first project bike to be successful. Thanks. Ask more questions so I can describe the whole picture if you're not seeing it.
- wireman
- Thank you received: 299
Try a new set of plugs and make sure youre getting spark on all 4 cylinders 1st before you mess with the carbs.
Let us know if you get spark or not.
- Demon650
- tattooist, fabricator, father, rider...
- Thank you received: 1
THE BIKE WILL NOT START OTHERWISE...I hope this helps, and she roars to life for you!!
also the gas to one side problem is common with these bikes from what I understand, try putting her up on the center-stand as you work on her, NOT THE KICKSTAND...this causes her to lean to far to that side and gas is probably pouring out the overflow.
-Beck
...once more, into the void...
- tinlizzie37
Bob KZ 650 E1, En 450
- Thank you received: 2098
thoshi64 wrote: 77 Kawasaki kz650b...gas is getting to the carbs...bike won't start...first thing I did was clean the carbs... airbox was missing...cheap...pods...reset the points correctly (pretty sure) and set the gap using a feeler gauge...haven't been able to get any combustion...new spark plugs...nice large spark... cylinder closest to the kickstand seem to be drenched with gas when I pulled the spark plug out while the opposing side was relatively dry...tried spraying some starter fluid on the pods and in the engine through the spark plug hole on separate occasions and nothing still....
With compression and spark, starting fluid should combust when sprayed directly into the carb air intake (pods removed) while cranking over the engine. If battery is low, use the kick-starter.
If there's no combustion under these conditions, would perform a compression test.
- OnkelB
- Thank you received: 80
Trace the spark plug wires from the plugs to the coils - the two outside plug wires (1 and 4) should connect to one coil, the two middle plug wires (2 and 3) should connect to the other.
Remove your points cover and trace the point wires (one black and one green) back to the coils - looking at the timing plate the left (rear) set of points should connect to the coil connected to the 1/4 plugs, the right (front) set of points should connect to the coil connected to the 2/3 plugs.
While you're in there also check the points cam/advance assy - the points cam has a small scribe mark on the outside edge (can be a bit hard to see with the advance bolt in place), this scribe mark must point toward the the small hole in the advancer or your points cam will be 180 degrees out.
77 KZ 650 B1, 82 GPz 1100 B2.
Opening of the points is the event that un-grounds the ignition coil which causes it to fire.
If Dyna-S has been installed (which replaces and eliminates points), wire colors to ignition coils remain the same.
When the rotor's embedded magnet passes the module, it un-grounds the ignition coil (same as points) which causes it to fire.
- martinhcoat
